Old 04-29-2024, 12:20 PM
MickIrlEC300 MickIrlEC300 is offline
Thanks for that guys.
I got onto trail tech too and they said I do need a load ( battery or capacitor) in order for the Reg/ Rec to work as it shunts DC voltage.
Using an old quad battery lying around I got it working and could see the battery slowly charging away while the bike was running with my fluke meter on it.
I am now in search of a battery (roughly 3.7AH similar to trail tech option but small in size to fit in the air box) or a capacitor but I?m unsure of what size capacitor to use.
From reading online I have seen a lot of different figures? trying to source one locally and I am planning to use maybe a 25v 2000-3000uf capacitor and hopefully this will get the lights working for me.
Old 04-30-2024, 10:12 PM
(F5)'s Avatar
(F5) (F5) is offline
I used to use an ignitech on some of roadrace bikes. I drove it with a CR250 stator grafted on. One bike used a CR rectifier regulator and it had a 25V 2200uf from vague memory. Next one I used a Chinese generic Ali express scooter rectifier and a Capacitor of the same size.
Bigger damps things more as does a battery.
Never had a problem.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 05-04-2024, 04:24 PM
So another update with the Trailtech RR.
I have connected a 50v 3300 uF capacitor into the system.
And with the fluke meter on the system the capacitor is charging up slowly ?. Probably reaches 1v after over a minute maybe 2 minutes.
When connect with the lights connected it immediately drains the capacitor.
I have now decided to just go ahead and find a nice and small battery with roughly 2-4ah and try to mount it somewhere in the air box without affecting any other parts of the bike. Iv seen some security batteries with high AH ratings and small dimensions so this may work for now.
So for now the bike is running good (idle is a bit intermittent) and I will be wiring up lights and just allowing the RR to charge the battery.
I feel the capacitor route will take too much trial and error to see what size capacitor will suit. Maybe the bulb I have is too strong 🤷🏽*♂️
Old 05-05-2024, 02:54 PM
(F5)'s Avatar
Oh dear. That's a problem. I started the racebikes by pushing them a few steps. The capacitor has to charge then the ignition start up then the bike fire up.
So instantaneously.
Your system is not charging properly.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
2006 ec300 wiring/lights clyde34 United Kingdom 2 09-07-2023 08:51 PM
GAS GAS SM 250 2002 - Lights Wiring Issue Help Yammotfra Enduro Electrical & Wiring 2 12-30-2020 07:52 AM
Wiring issue (lights) Lukeeccles Enduro Electrical & Wiring 6 10-09-2018 11:18 AM
2002 ec300 light wiring and speedo wiring help needed. andy176 Enduro Electrical & Wiring 0 02-04-2014 07:38 AM
