Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Other...
Old 09-28-2018, 12:52 AM
RHS outer case
RHS engine case, with a dirty big oil passage above the gearbox
Old 10-10-2018, 12:36 AM
Cox76y Cox76y is online now
What do you think the chance of this setup gunking up plugs. I have never wrecked so many spark plugs in 30 yrs of riding.. I'm definitely not running rich enough to be wrecking plugs..
If the hoses are blocked and the spooge runs back down into the cylinder could this be my cause? I haven't got around to blocking the hoses yet but another plug fouled on a ride today..
Old 10-10-2018, 02:43 AM
Pull the T piece out Josh, run the line from the right PV cover back to the air intake. Let the left PV drain to the atmosphere.
I doubt it's causing the fowling though. If jetting is right, plug is the right heat range gapped correctly, and you are still fouling I'd be looking at the rh crank seal.
fuel coming out vent hoses when petcock switched to reserve bluespark Enduro Intake/Carburetion - 2 stroke 11 07-29-2015 11:45 PM
Silicone hoses doddi1 Enduro Product Announcements 7 07-15-2015 08:45 AM
Silicone Hoses 450fse Zanderson Enduro Engine 4 stroke (including EFI & Exhaust) 2 06-19-2014 11:10 PM
coolant hoses adv rider Enduro Engine - 2 stroke 0 12-06-2013 01:36 AM
Hoses Fred1956 General Discussions & Announcements 3 01-19-2011 07:19 AM
