Old 11-03-2019, 11:04 PM
Hooligan Hooligan is offline
Originally Posted by (F5) View Post
Mate has just done with YZF450 forks and it is good when travel is being used but too 'everything' most of the rest of the time.
I am contemplating swapping a set of YZ KYBs into my 2010 EC250. Any ideas if the YZ steering stem is compatible with the GasGas steering head? I'd assume at least a bearing swap will be required.
Old 11-04-2019, 03:38 AM
Anders's Avatar
Anders Anders is online now
This question is covered here
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 11-04-2019, 01:46 PM
what i did with mine was got a second top t-clamp and had it machined out by a mm or 2.
I also retained the GG wheel by getting special spacers made to accept the yz axle
I believe all balls has a bearing conversion kit if you want to use a full yz front end
2003 txt250 Pro
2013 Ossa 280i
Old 11-05-2019, 12:10 AM
Elvis74 Elvis74 is offline
I have a 2006 KYB SSS fork in the original gasgas tripple clamps. I machines them as well. I put the original gasgas wheel with special made spacers in fits without problems
Gesendet von iPhone mit Tapatalk
4 strokes are only good for power generators
fork clamp bolts and fork oil level gassergrant Enduro Suspension 2 02-16-2016 04:08 PM
not all 5 wt fork oil is the same! matt_tidball Enduro Suspension 3 04-25-2012 06:21 AM
Fork oil?????????? Wicitup Enduro Suspension 3 02-15-2012 10:53 PM
fork seal change sachs fork Madhead Enduro Suspension 13 01-13-2012 07:49 PM
LTR fork Oil PEB Enduro Suspension 5 09-10-2008 08:07 AM
