Old 01-05-2011, 06:44 PM
widebear's Avatar
widebear widebear is offline
Banned
Klaus. You are correct the old settings do not apply to the new pwk's as the float bowl is shallower on the newer versions, looks like the latest rm 250 carb's minus tps. Anybody know off hand the revised setting?
Old 02-08-2011, 11:16 AM
stevehipkiss stevehipkiss is offline
Have adjusted My float bowl, now tickover is eratic, have I adjusted it too far, or is this a coincidence ??
Old 02-11-2011, 03:38 AM
iancp5's Avatar
iancp5 iancp5 is offline
Out of interest in the possible new erraticness - did you increase or decrease fuel level?
Old 02-18-2011, 03:47 AM
increased float height, therefore decreased fuel height in bottom of carb...this is why I'm thinking now not quite enough in bowl when ticking over...poss ???
Old 02-18-2011, 12:58 PM
iancp5's Avatar
Dunno, was just wondering if fuel height has much effect on idle. I can see how it could be effected but not sure if that would exhibit as erratic rather than just faster or slower or stalling.
Old 04-02-2011, 01:27 AM
Tlineman Tlineman is offline
Just pulled my float apart and measured 6.5mm on a brand new carb, 11 EC300 never ridden. I did notice that it dribbled a little bit when on the sidestand with a full float bowl. I bent the tab slighty to raise the float height to 8mm, hoping that this will clean up a spilling fuel issue. Checking the Keihin website I came up with a float height of 6.5 mm for the PWM carb, whick I think is right considering they still speck 16mm for the old screw top air striker. Gonna try a break-in ride tomorrow and see if there is a fuel starvation issue however I don't expect a lot of WOT.
Old 04-02-2011, 10:23 PM
Bike ran great today with a 8mm float level. Doesn't piss fuel at all when leaned over on the side stand or anything like that. Bike still is quite thirsty though. I'm gonna leave the float height as is.
Old 04-02-2011, 11:35 PM
HuskyDude's Avatar
HuskyDude HuskyDude is offline
Hey Tman where did you end up riding? I almost got out today but I had some things I couldn't get out of...maybe tomorrow.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 04-03-2011, 12:22 AM
Dew Drop, past Lac Du Bois PP. Very limited trails but some hills to play on and no snow unless you go high. The trees are spaced enough that a guy can 'freeride' through the area too.
Old 09-08-2013, 06:47 PM
Pinittowinit Pinittowinit is offline
Here's a cool trick
http://www.youtube.com/watch?v=Kgog_Ng0-2Q&sns=em
EC300 Idle Revisited. Ud_luz Enduro Intake/Carburetion - 2 stroke 35 01-07-2011 07:39 PM
Rear wheel spacers revisited. Ud_luz Enduro Chassis & Body 9 09-13-2010 08:01 PM
Zokes oil level? jostby Enduro Suspension 2 06-20-2009 11:29 AM
Fork oil level ? Brian VT Enduro Suspension 4 03-10-2009 08:57 PM
WP Fork Oil Level MattR Enduro Suspension 11 08-02-2006 10:40 AM
