Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Other...
Old 07-08-2020, 03:55 PM
Originally Posted by Gasser Nate View Post
If you were able to get the tyre back on the rim without levers, whoever installed it has broken the bead and that?s what caused the mousse to come out the side.
Seen it before a fair few times.
quite possibly, there is the right way to install a tyre with a mousse and a wrong way. The guys at six days enduro do it in about a minute and make it look easy
The hard way involves brute force and broken tyre levers and beads
2003 txt250 Pro
2013 Ossa 280i
Old 01-02-2023, 03:37 AM
henryJ7 henryJ7 is offline
just wondering does anyone run TUBliss gen2? What are your experiences, are mouses better? If so, what brand?
Old 01-03-2023, 03:15 AM
Anders's Avatar
Anders Anders is offline
It all depends on what you want. I don't run Tubliss, but the Swedish competitor T-Lock.
Mousse is better in some things, the Tubliss / T-Lock is better at other.
The feeling / advatages of having really light wheels (less unsprung and rotating mass) is the main reason why I run T-Lock instead of mousse.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 01-11-2023, 12:12 PM
motorhead's Avatar
motorhead motorhead is offline
Originally Posted by gasser nate View Post
if you were able to get the tyre back on the rim without levers, whoever installed it has broken the bead and that?s what caused the mousse to come out the side.
^^^^this^^^^
TeamFlannelOutdoors-somewhere South of I80
05' Gas Gas 300 DE
(Son's) 22' Rieju MR300 80th Anniversary Edition. 02' Gas Gas 250 XC
Moto Farm motor and suspension service 309 310 2540 leave a message
www.halls-cycles.com
Old 01-11-2023, 01:31 PM
I have run tubliss for many years, started with gen 1 in 2006 and eventually ended up gen2 - effectively the same, but gen2 refines some of the gen1 issues - if i remember it is things like rounder rimlock to prevent cutting through the tyre and thicker inner tube (i had my gen1 tube explode for no reason) but basically the same.
The benefit over a mousse is basically being able to change your tyre pressure as you want, whereas a mousse starts hard and ends its life soft so is only the correct pressure at a point in its life.
Mousse is puncture proof (provided it is installed correctly;-)) but tubliss can be plugged 95% of the time and provided the inner tube is in tact you can ride a flat tyre with almost no damage to the rim (i did about 50km of pretty extreme rocky riding at about 70% pace) on a sliced tyre and just replaced the tyre in the pits and rode the next day, the tubliss works like a full rimlock and also the inner works as a bit of a bumper about 20mm proud of the rim so even after the 50km the tyre was still in pretty good shape
in short, unless you are racing for a win i would rather go tubliss
(also it is also the easiest system when it comes to changing tyres - provided you follow the tubliss rules)
2003 txt250 Pro
2013 Ossa 280i
Old 01-12-2023, 12:53 AM
SS109's Avatar
SS109 SS109 is offline
I've run Gen 1 and Gen 2 Tubliss for over a decade now. I've also run Michelin bib mousse's.
If you like a more dead feel, and absolute zero chance of failure during a race if everything was done right, a mousse might be for you. If my last name was Jarvis or Lettenbichler then it would be the only thing I would run when money is on the line. That said, I hated them. They're a PITA to install and maintain, I hate the dead feel, and they are more costly vs Tubliss or UHD tubes.
I'll admit, I'm a Tubliss fan boy. I love being able to adjust air pressure to find what works best for any compatible tire, easier tire changes (even though some seem to not be able to do it ), lasts way longer than a mousse, and I can finish a ride/race even on a flat tire as long as it isn't a super soft sidewall type, and fixing a flat requires nothing more than a tire plug. I've had this setup now on four bikes, two KDX's and two Gassers, and don't see myself changing anytime in the future.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 01-12-2023, 01:44 AM
(F5)'s Avatar
(F5) (F5) is offline
Fanboy here too. Tubliss for trail.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Inventory Blow Out Sewerat General Discussions & Announcements 4 12-30-2019 06:10 PM
Gas gas aftermarket parts blow out sale County Cycle Parts 10 06-17-2015 07:21 PM
Blow by chchnick Enduro Engine - 2 stroke 16 05-07-2015 02:42 AM
Les Blow Trial- Vancouver Island South roughside Canada 0 02-02-2011 10:09 PM
That's a blow for you yanks TooFastTim General Discussions & Announcements 2 06-24-2008 08:20 PM
