Old 11-22-2022, 11:27 AM
Panagiotis Panagiotis is offline
Originally Posted by swazi_matt View Post
it depends on how much gap there is. measure the hole and measure the bolt. I believe it is normally the bushes and bearings that deform and the bolts stay good.
If the bolt is still good then just pack it witha bit of grease and when you tighten it, it could be fine
Thanks for replying , bolt doesnt show any wear at all but i will replace it , i just dont want any play in my suspension , i guess its my OCD .
Old 11-22-2022, 01:45 PM
swazi_matt swazi_matt is online now
does it still move when it is all torqued up?
my top rose joint had some play, and while i was waiting for a replacement i packed it with grease and it solved my issues. I sold the bike with a spare rose joint
2003 txt250 Pro
2013 Ossa 280i
Old 11-24-2022, 02:37 PM
I just finished assembling the bike ( i also changed sprockets , chain , rollers etc ) and now it doesn't make any noise when i lift the rear wheel and let it drop down , and with the bike on stand i move the swingarm and it doesn't sound like before so i guess it's good now though i didn't ride it yet .
Torque arm bolts need to be tightened at 81newtons according to the manual but i was afraid i might snap them so did them by feel .
Thanks again for the help
Sachs top bearing removal 5valve Enduro Suspension 7 07-12-2022 03:58 PM
2018 KYB shock bearing eralha Enduro Suspension 9 10-31-2019 04:10 PM
Lower bearing replacement in Sachs rear shock Blambo Other GasGas Bikes/Quads 1 04-02-2018 12:51 PM
ohlins shock bearing imsimon Enduro Suspension 7 12-12-2017 03:55 PM
rear shock bearing gassergrant Enduro Suspension 0 12-13-2014 11:33 AM
