Old 08-14-2018, 06:12 AM
mrfreezer mrfreezer is offline
guys.. I have PV assembly tight... with good preload, but PV have still freeplay...the triangle on right side does not move, but PV has 1-2mm freeplay... how to fix it?
Old 08-14-2018, 09:10 AM
gasgasman's Avatar
That's normal.
With the engine running, the free play will tighten up.
Old 08-16-2018, 01:33 PM
Guys.. I have cleaned my PV today and I was wondering about missing nut on left side... I know it should be without nut, but the left part of PV woulf be held away from flapper if there is nut... don't you think?
Old 09-27-2018, 03:09 AM
Anglosaxon Anglosaxon is offline
Have had the powervalve rebuilt with new plate/bearings etc after finding the original was totally butchered.
Still have, what I would describe as, a loud ?clacking? noise.
Is this the noise the pv tension fix should stop ??
Person who did the pv rebuild has stated he left a bit of ?tolerance? there which may account for still having the LOUD noise.
Old 09-27-2018, 03:35 AM
IME, these engines make noise.
The powervalve flapper has a heap of tolerance in it, if it didn't it would bind up and need cleaning more frequently.
The clutch packs can make noise, the pistons can slap around a bit too. An alloy bash plate will redirect everything back up at you.
Add in a few vibrations, sloppy plastics, rad braces, a slightly misaligned pipe, and you get a symphony of sound.
Loosen the chain a bit and hear that slap too!
Old 09-27-2018, 10:27 PM
Moto7man Moto7man is offline
Default Just Squeaky- Gassers Have Character Like a Ferrari.
Don?t forget the clutch squeal. I have a rekluse clutch with a rekluse basket in my 2011 gasser. If I am a gear too high it will squeal like a pig. I have been riding it since 2011 and I have never ever had the slightest problem. I rode a 2018 gasser with a rekluse clutch, when I was a gear to high it would squeal exactly the same way as my 2011,otherwise in the correct gear the gassers never make a sound. My 94 CR 250 has a Rekluse clutch with the torque drive plate system and a Rekluse Basket, it never makes a sound even if I am two gears too high. Go figure.
―Comedian Lewis Black
-Unknown Sardaukar
Old 09-29-2018, 09:28 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
What oil are you using in the transmission?
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 06-25-2019, 09:45 AM
Pygmygod Pygmygod is offline
Think I need to read through all of this thread.
Old 06-26-2019, 10:50 PM
adriano.ro adriano.ro is offline
So,the best way to adjuts pv preload? Is there tips to do that?
Old 06-27-2019, 09:16 AM
Jim Cook's Avatar
Thumbs up
Yes.
It is done at the governor, or bell crank which controls the pv movement as the revs rise.
The proper procedure has been described in detail on this forum.
You can find it with a search.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
Low down / tickover issue HELP stevehipkiss Enduro Intake/Carburetion - 2 stroke 9 02-14-2011 09:03 AM
jetting - idle issue. stainlesscycle Enduro Intake/Carburetion - 2 stroke 7 12-30-2009 02:47 AM
clutch issue boostedte37 General Discussions & Announcements 2 11-09-2009 06:58 PM
ec 400 gearbox issue Paul Somerville Enduro Engine 4 stroke (including EFI & Exhaust) 3 09-05-2009 10:17 AM
PowerValve Issue- Take A look at this Picture alexpp Enduro Engine - 2 stroke 13 04-12-2009 12:13 AM
