Old 01-11-2014, 04:42 PM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
Good write up mate.
How do they feel now?
Cheers Mark
Xr 250 ( first bike)
98 Rmx
2007 Gas gas 300(swapped for trials bike)
2008 280 Raga replica
2012 Gas gas ec 300 E
Old 01-12-2014, 08:32 AM
Vindicator Vindicator is offline
Had no time yet nor decent weather
Vindicator
'11 EC 300R
Old 01-12-2014, 09:14 AM
Removed the compression piston and cleaned all the shims:
Backup the compression rod all the way out before removing the PFP adjuster. Used the 22 to hold the PFP shaft on the top and a 14(?) to unscrew it from lower part of the shaft
Compression rod adjuster
Vindicator
'11 EC 300R
Old 01-12-2014, 09:49 AM
Cartridge/PFP cap :
That circlip on the shaft is what stops the PFP inner top cap from compressing the spring any further. Not a good idea to force the PFP once it reached the maximum of its adjustment .
Remove the circlip and use the octagonal cap tool to hold it and with a wrench on the PFP shaft unscrew it until the inner PFP cap threads are all out
As you can see there is another circlip at the bottom. This one is responsible for holding the PFP adjuster from moving on the cartridge cap . It's very important to have this circlip set straight, besides holding the PFP adjuster it also stops the steel ball and spring from the compression clickers from falling and sets tension on the spring:
Beneath the circlip there's a steel washer, once removed you just need to push up the PFP adjuster :
I did not use any strong grease when putting it back together because this is all fitted with small tolerances and the grease just makes it very hard to adjust all the parts including the compression clickers. Instead I sprayed everything with Motorex's Joker .
Vindicator
'11 EC 300R
Old 01-12-2014, 12:43 PM
The bushings on the PFP piston are done:
Is there a crossover for this ? I'm having a though time getting it from Marzocchi
Vindicator
'11 EC 300R
Old 01-12-2014, 01:18 PM
Word of advice:
Whatever you do, do not over-tighten the PFP shaft ! It holds a circlip on the threads that is supposed to act has a stopper when tightening both halves, the threads are very fragile. In theory, when done properly, this should give you the 26 clicks on the compression adjuster, if not, you need to adjust :
I think the engineers at Marzocchi could have come up with a less prone to mistake/damage solution than this...
Vindicator
'11 EC 300R
Old 01-12-2014, 10:19 PM
noobi's Avatar
noobi noobi is offline
Would it be appropriate to consider the PFP spring to be similar to a top out spring?
Old 01-12-2014, 11:06 PM
Not really noobi.
The PFP is Marzocchis equivalent to Yamaha and Showas ICS Spring, or WP/Ohlins N2 Charge (bladder/piston).
The internal chamber basically follows the same principals as a shocky, using pressure to reduce cavitation. A shock uses a resevoir and nitrogen (either via a bladder or piston). The PFP does the same to thing to the cartridge. Now think of a shock running very low pressure, and then one running a higher pressure. What the PFP does is allow an external adjustment for the fork.
Old 01-12-2014, 11:21 PM
noobi's Avatar
Not really noobi.
I thought that too, but it came up in conversation whilst servicing some YZ125 forks.
Old 02-04-2014, 08:53 AM
Motorockr's Avatar
Motorockr Motorockr is offline
Hi everyone, I'm new to the marzocchi cc fork. I have a question. I was messing with my compression clickers to get a feel for adjustment and I realized that my left fork has 27 clicks and my right only has 21. I have done tons of research on this to no avail. Am I overlooking something simple? I am decent with suspension but I am definitely no expert. Any help would be gratefully accepted!!
new 48mm Marzocchi forks?? Dave A Enduro Suspension 19 11-04-2011 07:48 PM
2004 ec250 ohlins forks, 46 or 48mm? Mikeythefokker Enduro Suspension 1 04-27-2011 10:39 PM
WP s or marzocchi forks Stoby Enduro Suspension 2 08-19-2010 07:16 PM
