#21
Hmmm I'm convinced people are getting too keen to mess with shim stacks before they've exhausted setup the normal way first: springs, air gap & clickers. Maybe I'm insensitive! Messing with shim stacks strikes me as something that requires either a huge amount of time for experimenting or a lot of expertise. Especially when they seem able to work well as standard to me.
A few years ago I took a Gasser to a well known suspension specialist to have it serviced. I asked about valving. He suggested that the Gassers were good enough as standard that unless I was a pro he wouldn't bother and just spend some time getting it set right with clickers instead. I found him to be correct. He could've taken some more money off me. If you'd just like to learn about suspension that's a different matter. |
#22
Of course your right, i'm not intending to get to involed with it, but if theres some common immprovments to be made, I'll do them. I dont have the time to go testing different thing, so at this point i'm just gatering information for possible things to try in the future.
As for the standard adjustments, I hav'nt tried everything, but the things I have tried did'nt have much or any effect. I can normaly make progress and find a setting fairly easily. |
#23
The clickers seem to have little effect because they are also a free bleed circuit in paralell with the large free bleed on the stack. All this bleed works good in the technical trails/rocks at slow to medium speed, but won't help keep the bike up at higher speed.
It depends who your suspension guy is. If he can't improve it that means he doesn't know how. A good tuner like Les will explain what he does and why, and help you understand and set the bike up. |
#24
What about adding rebound shims? |
Rear shock preload - Glenn has it figured out | Eric K | Enduro Suspension | 76 | 05-25-2016 04:45 PM |
Aftermarket wheel spacers. | Wiggy | Enduro Chassis & Body | 1 | 04-01-2010 05:14 PM |
Stiff springs and no-preload = good ride but? | stvbird | Enduro Suspension | 1 | 12-22-2007 11:42 PM |
fork preload | skid jackson | Enduro Suspension | 6 | 10-16-2007 05:57 AM |
