Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > GasGas Member Polls
GasGas Member Polls Find out what everyone thinks about it!
Old 11-08-2016, 06:37 AM
VilluEST VilluEST is offline
Originally Posted by Simmo737 View Post
Your starter problem is the battery, should read 13.8 to 14.2
That is only when bike is running and charging. Full acid battery voltage is 12,5V - 12,6V, not more.
Old 11-08-2016, 01:00 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
True, my bad, was reading off the trickle charger.
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 11-10-2016, 11:52 AM
5valve 5valve is offline
Talked to few dealers.
Since '15 there should be no known issues in the starter mechanism.
First kick from cold always start it by kick, then use button.
A few button starts in close proximity, and battery is drained. Only relay or plunger could be heard... tk tk
Next day measured 12.5V, connected it, got topped in 1/2hr, left overnight.
Now measures 13,0 few hrs after trickling.
It's no problem, if battery is to blame, but fear a sticking starter.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 12-16-2016, 06:48 AM
Originally Posted by memphis2857 View Post
After you ride that bike your plans will change. You will find the 50t sprocket unnecessary. I ran a 50t on my older GG bikes but on the 15 I stuck with the 48. Also the stock exhaust works very well and the 17 will ha e what seems like 2x the power of the older bikes. Once you get a taste of the e-start there's no way you will take it off. Just spend $75 on a lithium battery and throw the kicker in the trash bin. Lol
Now considering li ion, dealer said it is useless addon in tad over and below freezing temperatures.
Presume that if bike stored in warm garage, and while riding in freezing temp, its being charged, should be ok.
Maybe frequent start stops take its toll, if riding in low temps.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 12-18-2016, 07:50 PM
The trick with a Li-ion battery in cold temps is they need to "warm up". It only takes a minute at most. If you try to use the button right off the truck when it's cold chances are you will think your battery is dead. With mine I usually just turn the headlight on while I get dressed to put a load on the battery and then she will crank right over when the time comes. KTM even has some sort of procedure in their owners manuals now since they have switched to Li batteries.
Old 12-19-2016, 04:22 AM
stabak's Avatar
stabak stabak is offline
+1
common sense, why push the battery with cold start when you don't really need it then
EC250 2019
Old 12-19-2016, 01:48 PM
Spoke tu eastern EU dealer, he advised to always kick the bike when cold, then button it.
Something about longevity of the starting system.
So li ion all the way!
Key switch is already wired so that light is always on.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 12-20-2016, 06:52 AM
rubber Jonny rubber Jonny is offline
The newer small starter is the same as a KTM, they are ok but I would consider it a re starter, not ideal for using all the time it wont last.
Old 12-20-2016, 12:46 PM
My thoughts also.
Untill they get it as integral part of the engine, and give it more direct gearing, they are more prone to breaking.
I really like the suspension in the woods. Plush yet firm, but Is there a tool available for the PFP preload adjustment?
Would really mess up thin anodizing with pliers.
Also, stock chain seems too short.
Already had to loosen it a bit to get that min 3cm clearance, but tyre is now too close to shock protector and rubbing it away.
Its that overstretch sound when 50% or more wheel travel is reached.
112 continuous chain, no connecting link.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 01-21-2017, 11:26 AM
adriano.ro adriano.ro is offline
2015 motor is like a worked 2011
It came with an AS1 (imho better low end)
Waaaay better suspension
E start
Way better high speed and pretty much equal low speed handling
A generational leap me thinks.
Differences between 2009 and 2011?
KTM 2017 Sneak Peek. GG to play catch-up AZRickD All Other Bikes... 18 09-07-2016 12:27 PM
Tight and Dense NJ forest riding 2017 300 95jersey Pictures & Videos 1 08-26-2016 04:37 AM
Pipeguards for 2017 models available NOW!! Propower Enduro Product Announcements 5 08-21-2016 05:50 PM
2017 Bikes roll off the assembly line. gasgasman Enduro Product Announcements 13 04-25-2016 12:37 AM
Dirt Bike mentions 2017 GG 300 MxPhlipper General Discussions & Announcements 8 04-01-2016 06:26 PM
