#21
I understand and will agree. I believe the forks will turn out nice.
I really like the floating bushing in the bottoming cone...I thought of this years ago for thethe wp unitsand and it made sense. I think its even more plyable with the aluminum damper rod. Speaking of the dp I will have a new coating added to it. I have not decide with to do yet but it will be fun and slick.
www.synergyseals.com 209-938-9726 Being BOLD is BOLD! However, being confident is certain! Ride with confidence again! Made in the USA |
#22
You've got one sale here at least, virtually every Australian bike and most European are the Sachs/ Sachs combo, everyone says the same thing, harsh in the mid stroke with unnerving deflection on square edges, but a weapon in the woops!
Oz Current. 2015 ec300r estart, 98 RM 125 2013 Ec300r 2011 Ec300e 2009 Husky TE310 1982 XR500 Honda 1981 KE100 Kawasaki 1978 GT80 Yamaha |
#23
In the meantime, make sure you're sprung correctly - the 0.42s are soft for men of above average girth and/or speed.
#24
I am trying to learn these new forks as well. A little start up direction always helps. Rob
#25
check your pms and thanks
#26
But if I get a fix for the Mid, and could get a 12/.1 7mm id shim, I would swap back the 14 I moved, replaced by the new 12/.1 and add back in a 23.1, maybe two, above the crossover. the bike at the moment has lost a bit of its excellent control at pace over woops, braking bumps, jumps etc but is much more compliant over square edges to a point. I think it would still benefit from a two stage stack for enduro/trail in rocks and roots though....but i'm no expert, just a fiddler.
#27
#28
I did an interesting mod that worked out pretty well.
I flipped one base valve and added an oring to the cbore then added 4-24x.09, 4-22x.09, 1-18x.09, 1-14x.15,1-16x.09, 1-12x.09, 1-10x.15. This created more flow thru the bv but controlled the ls dampening better and helped with longer hs stroke absorption. My mv is a .25 check plate with a 1.35 float. This seems a little too much but I will play with it some. I also opened up the bottoming cone thru hole to 14.25mm verses the 13.75. I also open the nylon capture disk id to 14.25mm. Verses the 13.75. This helped big time with the binding that was going on. I also added our newer material seals on The forks. They feel buttery smooth. Rob
#29
Hey Rob
can you explain a little more extensively what you did with the o ring, and do you think with time the bottoming cone etc that you increased the i d of are a wearing part (to a point) that may be the reason that these forks seem to loosen up?, I'm suspecting not due to teflon being involved. Cheers
#30
The forks will not break in....if they do then the damper rod will have suffered. Rob
I Need A new Gas Cap - Options? | JP4 | Enduro Chassis & Body | 10 | 06-28-2011 01:59 PM |
Tubless options | lankydoug | Enduro Suspension | 14 | 10-22-2010 10:39 AM |
New hub options | Nick | Enduro Product Announcements | 2 | 03-02-2008 10:29 AM |
My options for a sub-mount? | d2w | Enduro Chassis & Body | 11 | 12-18-2007 03:02 PM |
