Old 05-01-2018, 05:51 PM
rvangeel rvangeel is offline
Thanks
Old 05-04-2018, 06:01 AM
VilluEST VilluEST is offline
I'm having the same issue with my Marzocchis, the bushing is almost dead rvangeel, please give feedback if the Sachs CC bushes fit?
Old 05-04-2018, 06:03 PM
I have contacted Richard Wilson, he has one used cartridge with good bushing that he is going to sell me. I only need the one bushing anyways. I contacted Zip Ty racing also, they seemed liked they would be able to get a set. The guy I talked to had to ask Ty, but he was not there that day.
Old 05-07-2018, 07:33 PM
rvktm rvktm is offline
there must be parts in italy . iv got a mate who works out there
Old 05-07-2018, 09:00 PM
the 35 mm marzocchi shiver used on ktm 65 fork uses a inner bush 35 od 15 iong 1mm thick
Old 05-09-2018, 03:52 AM
Could you check it out with him if there is something available in Italy?
Old 05-11-2018, 01:07 PM
is the size of the bushing and fork parts 36 od 34 id 15 long 1mm in thickness , did the non adjustable ppf cc 48 use the same bushing
Old 05-11-2018, 01:38 PM
need the dimensions of the ics ppf spring id od length spring wire diameter thanks not found if marzocchi italy are still going
Old 05-12-2018, 07:54 AM
Default Need to find Inner cartridge bushings-48mm marzocchi’s
Here is some more info regarding the sizes and a video showing how the 0.1mm larger diameter does not fit inside the cartridge.
Just to be clear, the racetech bushings do not fit. I have found a used bushing that is in good condition and will install it when it arrives next week.
https://youtu.be/ykj2cDIzpvQ
Old 05-12-2018, 08:13 AM
102mm long
26mm OD
19mm ID
3.6mm wire dia
The springs on these cartridges (the forks have enduro engineering stickers on them) seem to have been apart before so I don’t know if these are stock springs. There is a part number on them... 341620 on one coil and then a 14 on the next coil.
PFP adjuster on 48mm Marzocchi’s rvangeel Enduro Suspension 2 03-18-2018 03:26 AM
Marzocchi 48 Cartridge Problem fixmare Enduro Suspension 30 09-11-2017 05:38 AM
Fork Oil Volume for 2013 Shiver 48mm Closed Cartridge scov Enduro Suspension 3 04-21-2013 02:04 AM
Sachs 48mm Bushings Jakobi Enduro Suspension 9 06-19-2012 07:18 PM
