Old 05-09-2015, 03:37 AM
I haven't seen one that looks the same as those pictures. What does the other side look like?
If you do indeed need to remove that inner section the right tools will be a clamp that accepts the OD of the seal head, and a pin spanner or custom tool that fits well.
From memory, every Sachs seal head I have seen you simply need to remove the snap ring on the back side and everything comes apart.
Old 05-09-2015, 05:14 AM
5valve 5valve is offline
Oil filter wrench with strap did cross my mind, but it has a lever with knurled area for better contact on filter surface,
so would need to put protective rubber beneath the wrench and hope it would hold the torque.
I also hoped for the easy type body, with washer only, but was once again proved wrong.
Making OD seal head tool would require yet another machinist work, probably out of non slipery hard plastic.
I found that RXV has the same type seal head, but no one yet has opened it.
http://i1231.photobucket.com/albums/...V/IMG_2582.jpg
This is the other side after removing rubber stop. Bushing also calls for replacement.
Old 05-09-2015, 10:29 AM
Managed.
Some tweaks to the tool and a firm grip with adjustable pliers on a non contact surface.
Seals measure:
dust 22 - 16 - 3/4??
oil 24.4 - 16 - 3.4
bushing 18 - 16 - 11.9
Is this the same for all 16mm shaft shocks?
This material is impossible to come by in my country, will need a drive to Italy.
Old 05-09-2015, 05:44 PM
With the style that uses a flat plate and no top out spring I would simply source a complete SKF seal head. I used one in another style but had to machine a spacer and remove the top out spring.
Old 05-09-2015, 05:47 PM
http://www.suspensionworld.eu/shops/...-seal-head.pdf
Measure it up. I'd say Beta listing would be right. Quite a few variations of these Sachs units
Old 05-09-2015, 07:02 PM
Thanks. I see gas is actually listed in TM section.
Old 05-09-2015, 07:21 PM
Measure the dimensions of your seal head. The Part numbers inc ID/OD/Height
ie. 16-50-24
I'm betting your shock will use those above. The ones with the top out spring use the 15mm seal head. Any changes here will be reflected in the shock length (which is even greater differences in chasis once the linkage is taken into effect).
Old 05-10-2015, 04:13 AM
OD 50 is the measurement being correct.
It's 26 high.
Presume that ID is measured with teflon bushing installed, making 16 ID also correct.
Since SKF is aftermarket, maybe their product is lower then OEM, thus the 15 height being correct (16 - 50 - 15)
You made me think now, since all sales advocate the 15 seal head for gasser, but the beta model being the closest to stock height.
Old 05-10-2015, 04:22 AM
Flashed my mind.
If I measure the height of the 50 OD area only, it gets us closer to 15.
This being correct or not..not sure any more.
Old 05-10-2015, 06:00 PM
You second pic is correct. There can be a few mms difference between the OEM and SKF in some situations. I compared a 300EXC piston which measured around 17mm, while SKF parts state 15mm.
As above, the Sachs shocks come in a variety of configurations. Some use a top out spring, some use a larger plate. All seem to use that stupid snap ring on the shaft which means you need to remove the clevis to access the bump stop (which isn't hard really).
Below is a pic of the seal head I pulled from a Husky WR125. From what I can gather, SKF have not manufactured seal heads for use with the Sachs variety that use a top out spring. In your case you should simply be able to source part 'SH-ZF-16-50-15' and it should be a simple install.
As you can see, this Husky Sachs used a much deeper seal head than yours. It was a 50mm OD, 16mm shaft. The nylon plate recessed into the seal head and locked into position with a circlip (resting on top in the pic) is where the stop out spring would ride.
Most tuners here (in Australia) and most likely in general, machine out the OEM seal head to accommodate either a KYB/Showa seal as they are cheap and easily available.
Service manual for Sachs rear shock MattR Enduro Suspension 9 10-19-2016 03:18 PM
New sachs shock baker Parts 4 03-25-2014 06:02 PM
2001 EC300 Ohlins Shock Help: Service and Setup krazy Enduro Suspension 7 11-24-2012 05:07 PM
