#21
Ride report 07 sachs
Bikes
ec300 sachs rear ec 300 Ohlins rear ec200 Ohlins rear 2 x KTM 525 06 DR350 - that just wont die we all went for a decent trail ride on sat, But i thought before that ill try out the revalving on the rear shock Hmm much better But still really Hard We checked the race sag from the 5.2 Kg spring - im 85kg with out riding gear - 89 mm Max, 11mm spring compression which in my book meens its to hard for me, But ill ride it and see if it frees up. Hmm didnt free up riding over small jumps, lets go for a ride anyway Shane and i swapped bikes ( ec300 ohlins ) wow i could not belive it how good the ride was, shane stopped beside me and said i thought you were just bitchin obout the rear end now i beleive you I want My bike Back! - Shane weighs about 90kg so ithought he would be ok on it. As a side note i Checked the entire linkage system before reassembly and Found NO grease on the O rings But found Plenty of grease in the bearings this had the affect of limiting the action on the linkage it would hang in mid air . I placed a feeler guage between the washer and the linkage and found min .88 mm clearance - I fitted a .84 fibre washer which was nearly the same size as the steel washer. You can find out what happend to the gearbox in the 2 stroke engine section. Not Happy JAN |
#22
all the bikes come with marzocchi forks and either a sachs rear or ohlins rear. the price is about 300 bucks and shocks are about the same its the setup that makes or breaks the shocks, having them setup for the rider is a must and will make them perform to your needs.
#23
I contacted Gas Gas Spain and it looks like the importer is correct.
From February 2007 the Ohlin option has stoped. Gas Gas sent out bikes with Ohlins rear as they did not have the Sachs in the 1st lot of bike made. After riding the 07 bikes why bother with the Ohlin all I can see is that the 07 bikes have a firmer seat the rear shock was fine and as far as the O-rings binding I dont think so. |
#24
my rep has prices for the sach and ohlins model and I can still get the ohlins shocked bike as of last week I have not heared any different
Triple Threat Motorsports For all your Gas-Gas, Husaberg, Kymco and Husqvarna outdoor equipment needs. 2003 Atk 450 Xc Quad Ported,Stroked, and ready for action, Ohlins suspenders, protected by Prm, TTM, Hiper Technology, Cycra, Streamline, Kenda Usa, Regina Chains, Amsoil, Motortabs, Rb Components, Pro Taper, Ac racing, Dirt works Motorsports. |
#25
If your distributor still have Ohlins bikes in stock they will be able to supply
but Gas Gas in Spain has no more other than the R model and a lot of the 07 bikes that did get sent out with the Ohlins did not have the High and Low speed adjustment like the 06 bikes not all of them but most of them did not have it.It is like the 1st sipment of FSR450 that got sent down under they all had Ohlins because the Sachs was not ready and this could of been the case in the U.S I did not get this from a sales person I got this from Gas Gas Spain they should know. |
#26
I've seen the '07 Ohlins. Its not the same as the previous Ohlins, appears to be different. Aluminum body, no HS adjuster, rebound clicker screw not thumbwheel.
Get the Sachs, your not missing anything. |
#27
As far as bearings goes, congrats to GG or your dealer for properly greasing the bearings. Typically, they treat the grease in bearings like gold and there is very little. Looks like you were setup good.
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
#28
The New Sachs Is Better Than The "new" Ohlins Anyway
The Ohlins Rear Shock That Comes On The 07 Models Is Junk Compared To The Previos Models & The Sachs Unit. It Now Has An Aluminum Shock Body, The Compression Adjuster Has No Clicker In It, And The Rebound Adjuster Is Just A Screw Now, Not The Big Knob Like They Used To Have. So Be Thankful You Go The Sachs. 42 George
#29
still cant get the sachs right
I met a bloke on a 07 300ec on the weekend with the same sachs shock with the same problems as me, to hard, nice to know its just not me, and yes i found out the ohlins that did make it onto the 07 models were not the same as 06.
I did 120klms on sat then 60 klms on sunday and still cant get it right, but i did find if i never sat down and avoided "every" bump it wasnt to bad. |
#30
Could the problem your having be caused by the spring being too stiff? I am running a 5.0 on the back of my 06 DE300 for my 180 pounds. The bike came with a 5.4. I ride A class. We also have a 5.0 on the back of my sons 06 DE250. he weighs 170 pounds and races AA. Both bikes have the ohlins shock. Dave
How to find the GasGas manuals... | MattR | General Discussions & Announcements | 60 | 10-11-2022 09:20 AM |
where can i find a cheap set of handguards? | dank | Enduro Product Reviews | 5 | 03-01-2010 02:03 PM |
I'm back, now find me a bike! | Bandit9 | General Discussions & Announcements | 19 | 12-09-2009 11:19 AM |
Disturbing find.....! | bukwheat | Enduro Suspension | 15 | 03-17-2009 09:54 AM |
Any dealers here who can find me a.... | Xman218 | General Discussions & Announcements | 5 | 04-02-2008 08:38 AM |
