Old 11-27-2007, 09:05 PM
Link Link is offline
The bearings are not a new idea. At least in road racing Ohilins has been recomending & selling those for a long time & some Ohilins dealers/gurus will not set up a shock without those in place. So I'm sure they work allowing the spring to rotate with out binding keeps the spring rate more consistaint, but on the asphalt the maint. on those would be yearly. In the dirt that thing might be toast after a few rides.
Old 03-24-2008, 08:36 PM
gasgasman's Avatar
Check this out.
Hydraulic pre-load adjuster. 15mm of adjustment with a T handle.
http://www.mergeracing.com/products/...licPreload.php
Old 03-24-2008, 09:03 PM
Intersting ....
no olins tho.
Old 03-24-2008, 09:08 PM
gasgasman's Avatar
Just think.
You can have a small pump on the handle bars to change the pre-load on the fly.
Deep sand section coming up........drop that rear end.
Old 03-24-2008, 09:28 PM
GMP's Avatar
GMP GMP is offline
My neighbor has one on his BMW road bike (Ohlins) Pretty slick. The Ohlins version has a remote master cyl. on the subframe with a knurled knob you can eaisly grab and turn for adjustment. Great for when he adds bags or a passenger.
Once I got mine where I was happy though, I never touched it.
Old 12-05-2008, 09:22 AM
iancp5's Avatar
iancp5 iancp5 is offline
I guess the ultimate would be fully electronically adjustable suspension but I think I prefer what's cheap and reliable.
Old 04-27-2009, 08:35 PM
gasgasman's Avatar
Originally Posted by Eric K View Post
I reduced my preload from about 12 mm to 10mm, which changed the loaded sag from about 125mm to 130mm.
Can you post the step-by-step procedure on how to do this.
Thanks.
Old 04-28-2009, 07:55 AM
jostby jostby is offline
Thanks.
Pretty easy stuff. The preload is the amount you compress the spring with the adjusting nut/ring. Support the weight of the bike on a stand and back the nut off until it just touches the spring to have zero preload. From that point the more you compress the spring the more preload you have, measured in mm's.
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 04-28-2009, 10:35 AM
gasgasman's Avatar
I have my sag set at 100mm.
I'm just wondering about the 125-130mm sag.
Wouldn't that "rake" the front end out too much?
Old 01-05-2010, 07:43 AM
stainlesscycle's Avatar
i have the same question - i just set my preload at 10mm, and i get 120mm of sag.. i normally would run around 105-110mm. will 11mm or 12mm of preload get me to 110 and still not sacrifice rebound etc? it's too cold to go out and run it, but i would think 120 would sacrifice turning ability... i've got a 5.4 spring, ltr lowering link, and 195lbs with full gear. also my static sag is 55mm... seems strange to me (i would assume it would be closer to 35mm... ) - does the lowering link affect static sag that much (i would assume it changes the leverage)?
washers on lower rear shock? lineman12345678 Enduro Suspension 19 06-20-2014 04:35 PM
Rear Shock Spring--Where Am I? Where Do I Go? smstewart Enduro Suspension 0 04-19-2010 05:35 PM
07 ec250 will 05 ohlins rear shock fit gasgasandrew Enduro Suspension 1 01-22-2010 04:39 PM
Removing Rear Shock gasIdaho Enduro Suspension 12 02-04-2009 10:45 AM
rear shock sag under bikes own weight rupecopp Enduro Suspension 7 12-18-2007 08:06 PM
