Old 11-08-2014, 02:06 AM
(F5)'s Avatar
(F5) (F5) is offline
Jake have you not revalved those S3 s yet? What the blue blazers is going on man?
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 11-08-2014, 03:21 AM
Originally Posted by VxZeroKnots View Post
Honestly, first service, there was some crud in the oil. Second same. I'm dreading my third oil change at 135ish hours. I wonder if it is even worth picking up a set of bushings. Regardless, I'm going to ride them totally into the ground but it would be nice to know there is a nifty backup.
I'm very curious about your thoughts regarding the change in trail. I love the bike's slow speed handling, but if it was a little more stable at speed without knifing excessively in gnar I'd be thrilled.
By crud you mean.. Sludge, alloy, dark oil? Its normal for the oil to break down and smell bad. Bit of sludge in the bottom isn't unheard of either. It was the alloy from the spring seat which I attribute to eating mine alive.
Honestly, the trail is a concern. While the theory dictates that a smaller offset (more trail) is more stable, the real world testing usually shows the bike to be better in the slow speed and tip in, but perhaps a little too active as the speed increases. Mostly knifing/over willing to continue turning when you want it to stand up. Think big drifts and how a well balanced bike will just settle and slide. Not enough trail and the bike will run wide, too much and it wants to tuck in. It also effects the weight on the front tyre and considering that I don't find the Gasser the kind of bike I really have to scoot right up the tank on often, it may be too much. Time will tell, and if its no good then I'm a bit shot for options. Stock Yamaha clamps for this fork are also 22mm offset same as the Gas Gas ones. I could go an earlier model and shim the upper clamps (or the e-axle).
I like the stock geometry of the Gas Gas, I think the 2012+ feels a bit more stable than the 2010. I never had issues with the 2010, so hoping I'll end up somewhere inbetween the two.
I was hoping you'd put the leg work in on this one Yours are ready for testing.. Mine not so much.
Old 11-08-2014, 06:39 AM
Rake angle measured approx 27 degrees which is same as (and in approx range of, give or take a few fractions of a degree) most other current bikes. YZ250 YZ250F CRF, and also the Beta 2T range uses a 27 degree rake frame.
In comparison, alot of the 4T bikes are running a 32mm offset lug and 20mm triple clamps. The Beta 2Ts run a 35mm offset lug and 20mm triples. The ECs use a 35mm offset lug and 22mm triples.
Glenn reported the -3mm offset to be too much on the Beta, however given that the Gasser starts off +2mm ahead of the Beta it may work out being an overall improvement.
Thinking about my comments earlier about how I never scoot up the seat on the bike, I do find myself riding on the pegs, head well over the bars quite a bit though. I'm definitely not stressing over the change yet.
Old 11-08-2014, 10:11 AM
VxZeroKnots's Avatar
VxZeroKnots VxZeroKnots is offline
Sorry for being vague, dark oil with a hint of alloy. Though a fraction of what your picture showed.
I flushed it as best I could and the bushings didn't really show wear so maybe I'll be okay for a while.
Old 11-08-2014, 03:50 PM
(F5)'s Avatar
Pah! Me? I should be riding it today, but I'm unable to due to poor planning (and a bit of bad luck ). Either way I kinda know what I don't like but I'm harder pushed to know how to fix it. Something easier on my elbows than my 45s and to not be deflected off greasy tree roots and we'd be a good way there.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 11-08-2014, 10:42 PM
I'll let you know what I'm thinking after I put some time in checking things. The thing I'm sure of is that the stock YZ valving is going to be too firm for my purpose. But maybe not too much. I'll sus out the stock setup and then put a few suggestions forward.
Comparing a geometry a bit more, have also been looking at the wheel bases of the typical 2T enduro/mx ranges.
Ktm 1482mm
Beta 1480mm
Gas Gas 1480mm
YZ250 1480mm
YZ250F 1466mm
Not sure that the actual wheelbase will make any noticable difference, and in any case I have a new chain on hand and was planning to move the rear wheel back some to add some leverage to the shock and see if it would track better on snotty uphills. It may be that my front wheel moves in 3mm and my back wheel moves back the same.
Also, the measurements are simply what each brand specify so could be some variance in to what point the actually measure. Also depends where the rear wheel is set in the blocks. Each value really could be +/- 10mm.
Old 11-08-2014, 10:47 PM
gasgasman's Avatar
I have the OEM YZ125 forks with stock valving and springs.
It's not that bad. I weigh 190 with gear.
I do bottom out on the MX track.
Old 11-09-2014, 12:01 AM
What year forks? Quick check would put stock springs at .42kg/mm and I imagine the 125 would probably be setup a touch lighter than the 250.
The forks I'm getting have come from a 250F. I would say a heavier bike, but people won't be able to help reminding me that there probably isn't much in it between the Yamaha and Gasser. They'll be valved for more weight on the front end though, and coming with .46kg/mm springs which should be OK.
I'm running .44s in the Marzocchi and .46 in my previous TTX equipped. Should be good if I can get some preload off them.
Old 11-09-2014, 12:12 AM
nknudsen's Avatar
nknudsen nknudsen is offline
On my 08' 250F SSS forks I went from .46 springs back to the stock for that yr .44 springs. I do like the .44 springs better (190lbs) but I also stay off the MX track.
Noah
2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title
16' Ski-Doo XS Renegade X 1200 4T
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been)
15' TW200
Old 11-15-2014, 06:42 AM
Isn't it time you guys updated this post? Need a fix!
2003 txt250 Pro
2013 Ossa 280i
2013 ec250r Jakobi Enduro Product Reviews 163 02-21-2016 03:52 AM
2013 EC250R - 65Hr Report/Review Jakobi Enduro Product Reviews 111 03-07-2015 07:33 PM
2013 ec250r Jakobi Enduro Intake/Carburetion - 2 stroke 2 04-17-2014 08:08 PM
2011 Gas Gas EC250R EricW835 Used Bikes 3 10-20-2013 10:58 AM
