Old 05-12-2018, 08:35 PM
rvktm rvktm is offline
skf do a 36 od 15 long 1mm ktm 65 mar 35 fork slide bush
Old 05-22-2018, 11:55 AM
SS109's Avatar
SS109 SS109 is offline
So, did anyone ever come up with a definitive application crossover for the forks springs?
I have two tuners locally tell me that they need to pull them so they can match up a spring. I plan on doing all the service myself so I would like to have springs ready to go when I pull them apart.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 05-23-2018, 10:46 PM
twowheels's Avatar
Main spring or PFP spring?
Steven Beane #275
afterhourscycle.com
Old 05-23-2018, 11:13 PM
SS109's Avatar
Main springs.
'11 EC250R
'98 KDX220
Old 05-24-2018, 02:11 AM
VilluEST VilluEST is offline
Should be FRSP 4447, only thing this is 5mm shorter than original. You just need to adjust the fork spring preload clip one notch further.
Old 05-24-2018, 02:32 AM
SS109's Avatar
Thank you!
'11 EC250R
'98 KDX220
Old 06-02-2018, 02:07 AM
Anders's Avatar
Anders Anders is online now
For the record:
I found the pfp springs on my 15 200 to be 1.4 kg/mm. I measured one using my bathroom scale, and used the milling machine to compress it 20mm. Then the scale showed 28.3 kg.
I will try to replace them with Racetech springs of 1kg/mm, just to see the difference.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 06-02-2018, 12:40 PM
hi anders are your ppf springs the original marzocchi ones . no one had anything in the uk softer than 1.6 .looking to get some 1s myself .anyone no what rate my 013 ppf springs are
Old 06-02-2018, 01:42 PM
Anders's Avatar
I'm the only one that have worked on my forks. So I know for sure that these are the OEM pfp springs.
I bought mine 1.0 springs on ebay from the US.
http://r.ebay.com/pZYjgj
Anders
1986 Duc Mille S2
etc
Old 06-02-2018, 07:32 PM
SS109's Avatar
Curious how the lighter pfp springs will affect fork performance. What are you trying to achieve with them?
'11 EC250R
'98 KDX220
new 48mm Marzocchi forks?? Dave A Enduro Suspension 19 11-04-2011 07:48 PM
2004 ec250 ohlins forks, 46 or 48mm? Mikeythefokker Enduro Suspension 1 04-27-2011 10:39 PM
WP s or marzocchi forks Stoby Enduro Suspension 2 08-19-2010 07:16 PM
