Old 06-02-2018, 08:02 PM
rvktm rvktm is offline
my 013 forks are good if your riding aggressively not so if your not .its to stiff at the top of the stroke got the ppf backed off
Old 06-11-2018, 01:01 AM
Anders's Avatar
Anders Anders is offline
Originally Posted by SS109 View Post
Curious how the lighter pfp springs will affect fork performance. What are you trying to achieve with them?
I am trying to build a fork that is soft/plush enough for my use, meaning that I use the whole travel in the typical terrain (rocks, roots, slow speed) that I ride. I would like the fork to do this when I have it in the middle of the adjusting range (10-15 clicks compression). When achieving this, I will be able to actually use the adjusting range of the compression clickers and pfp. When I started out, I used the pfp at minimum preload, as well as the compression clickers all backed out. The forks were still too stiff for my use.
I am quite pleased with my latest setup. I have polished the springs and the lower fork legs, rebuilt with SKF seals and Intec bushings, softened the compression stack and installed 1.0kg/mm PFP springs. I presume my compression stack would be too soft for most people, but I am a old and slow racer If I get faster, I can just put back a compression shim or two.
I ran 15 clicks compression and PFP all the way out in this weekend's race. When finished, I verified that I had used all the fork travel, without noticing any hard bottoming during the race. When riding, I felt the forks were plusher than before, and responded well to all the rokcs and roots (at my pace). In other words, I am close to where I planned to be.
Tomorrow I'm off to a MX club race, the setup there will be PFP 3-4 turns in, 5 clicks compression (or there about).
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 06-12-2018, 02:55 AM
SS109's Avatar
SS109 SS109 is offline
Please let us know how it does.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 06-12-2018, 12:48 PM
look up oemcycles on ebay 26 uk freepost for the ics springs and a bit of import duty thanks anders got someone interested in the 13 just need to get rid of my 05 ec the 99 txt and a 490 maigo ill get a 18
Old 06-13-2018, 01:44 AM
Anders's Avatar
On the MX track it is too soft, even for me. I bottoms hard when landing from jumps, particularily in a step-up where I don't jump to the top, meaning that I always land uphill. I tried 3 clicks from fully closed on the compression, and 4.5 turns PFP. Next time I will try more PFP. And perhaps add a little oil, as I have only 250ml in each leg now.
But the lack of MX performance is OK, as my main priority is to have a good enduro setup. I don't feel at home on the MX track, jumping big jumps has never been my cup of tea.
However, I ride MX from time to time. We have a club championship where MX and enduro points are collected to make up the chapionship standings. So I have to participate in all races to collect some points
Anders
1986 Duc Mille S2
etc
Old 06-15-2018, 12:03 PM
just a though anders how about using 1.0 isc spring in one leg and a 1.4 in the other ? if you had a choice of 1.0 or 1.2 ics springs ?
Old 06-15-2018, 05:32 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
I used to jump every chance I got, and loved to fly (in my younger days, on a bike). I've gotten older (in spite of my activities for the last 65 years).
I no longer have any desire for "Big Air" on my bike.
I say, "Big Air? Kid, If you want Big Air, pull my finger."
Good Luck and Good Riding to You!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 06-20-2018, 02:19 AM
Anders's Avatar
I think I'll stick to the softest ICS springs for now. Yesterday I did some laps on the MX track again, and with 7.5 turns in at the PFP and 2 clicks out on the compression it is acceptable at my pace for now. To me, the woods performance is the first priority.
Anders
1986 Duc Mille S2
etc
Old 06-29-2018, 03:32 AM
SS109's Avatar
Just broke down my right fork and oil was 270cc for outer and 210cc inner. It was very dirty looking but I didn't see any contaminates in the oil.
I have a main fork spring preload question. My forks were set a zero preload (top clip). Should I leave it or should I set it to the factory 5mm of preload? I want my forks plush but I know the forks were designed to have that 5mm preload on the spring. Any advice would be greatly appreciated!
Also, just an FYI for anyone looking for main fork springs, I bought a set of genuine KYB springs that fit the '07-'10 KX450's. They are listed as 470mm but appear to be 475mm and identical to the ones I pulled out. Got a steal at only $60 brand new off Ebay.
'11 EC250R
'98 KDX220
Old 07-03-2018, 06:52 AM
SS109's Avatar
Another important question, do I need to use Loctite (and what type) on the junction of the PFP and the compression stack(?) rod? In this pic from Vindicator, where these two parts thread together underneath the PFP spring? Also, am I correct in that this is where you adjust for the proper amount of compression clicks or is that a different spot?
The stack in the cartridge. Does it look ok?
(Left to right, top to bottom)
Bolt
Spring
31.85 x .3
Base
11 x .3
11 x .3
18 x .1
20 x .1
24 x .1
13.8 x .1
31.8 x .15
31.8 x .15
28 x .1
2.5 spacer
Lastly, in between those two parts mine has a circlip on each one. No clue why they're there as I haven't seen them in any other pics of this junction.
'11 EC250R
'98 KDX220
new 48mm Marzocchi forks?? Dave A Enduro Suspension 19 11-04-2011 07:48 PM
2004 ec250 ohlins forks, 46 or 48mm? Mikeythefokker Enduro Suspension 1 04-27-2011 10:39 PM
WP s or marzocchi forks Stoby Enduro Suspension 2 08-19-2010 07:16 PM
