Old 02-25-2020, 03:14 PM
Gasser Nate's Avatar
Pretty much that same mate when I checked it when doing the jetting initially, I only ever change it when I do a top end and never really look at it until then.
I only need to change the pilot to a 42 and tweak the air screw in winter.
Old 02-25-2020, 05:32 PM
Gez Gez is offline
Good to know, I have a 42 here but found it abit blubbery when I tried it last year during winter. It's there if I need it though
Old 02-25-2020, 06:09 PM
(F5)'s Avatar
(F5) (F5) is offline
Forget jetting by plug colour. It's a road race tool that only tells you main jet and only if done under controlled test. Just pulling the plug out and looking at it is only going to tell you something might need changing, maybe. Or that it looks like you should change it. Or that it should be in the bike for it to run.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 03-02-2020, 01:53 PM
ricar116 ricar116 is offline
N1EF and #7 slide in 2nd clip too rich for my riding style in hilly tight rocky Missouri. I could foul plugs easily off idle when cold.
Bike year & model = 2018 XC300
Temperature (degF) =55F 13C
Elevation (feet) =960
Main jet = 175 (stock)
Pilot jet =42 (stock)
Needle & notch =N1EG 2nd
Air screw setting =1 5/8 out
Throttle valve/slide = #8
Results: Using Motorex Cross Power 40:1 95 octane unleaded. No plug fouling very predictable linear power no dips no hits. Great idle easy start. Curious to see how she works at 100F 38C hope to stay with a "G" needle. I love this bike!
Old 03-16-2020, 01:07 PM
hannesd hannesd is offline
2015 ec200
sealevel 5-15 Celcius
AS1 screw top cap carb
squish untouched, will get into it when i change the piston.
MJ 175
PJ 42
needle CDM #3
this setting gives a nice midrange and ok top.
previous setting (when i bought it) it came with following setting:
MJ 172
PJ 45
needle CDM #2
this gave a tiny bit better really down low but was flat up top.
there was quite some spooge with this setting.
Old 03-20-2020, 05:20 AM
JoseGas25's Avatar
JoseGas25 JoseGas25 is offline
Hello, some of you have try the NECW needle?
Here in Spain it is very famous. I have a 48, 172 and NECW and the bike is very very smooth and progressive in the low rpm.
Sorry for my english, I am Spanish hahhaha
Old 03-20-2020, 02:10 PM
SpirosZ1000's Avatar
SpirosZ1000 SpirosZ1000 is offline
Smartcarb to last bike (2015 ec300)
Transferred it to current 2018 250 GP
Problems SOLVED
(But now I don't have anything to change every now and then on the bike)
Gas Gas EC 300 2006
Gas Gas EC 300 R 2015
Gas Gas EC 250 GP 2018
Old 03-25-2020, 12:43 PM
Jose, what bike and year? 250? 300? You run a 48 pilot? Which clip position (from top) is the NECW?
Old 05-22-2020, 03:14 AM
Gez Gez is offline
Rode the bike again this weekend just gone, this time in the bush. Same jetting as the mx track. Bike felt strong everywhere, PV adjustment worked really well for the bush.
Did a quick fuel drain out to see what consumption was like. Did 49.5km and consumed 4.5l of fuel, absolutely stoked with this consumption. It means 100km loops are possible if needs be.
Riding again this weekend, hopefully I'll do another fuel consumption test and see where I'm at.
2018 EC300
MJ: 175
PJ: 40
AS: 1.5
NEDW: #2
Old 05-23-2020, 02:45 AM
2018 EC300
MJ: 175
PJ: 40
AS: 1.5
NEDW: #2
First ride 2020 yesterday. I jetted the bike exactly the same as my previous bike (300 EC 2019) and the fuel consumption is far too high.
I wonder why the fu*k I can get all my mates bikes right just struggle with me own one. Bloody hell!
20? C, 300 EC 2019
MJ: 180
PJ: 42
AS: 2
JD-RED: #3
Consumption was 3,75 liters for 29,7km in easy terrain, but only gears 1 to 3.
That's too high. My previous bike at the same track with same jetting would have used 2,75 liters.
Yes, my float height is right and the bike didn't spill any fuel, I also have the overflow hose looped acc. JD's recommendation...
I wonder if the smaller PJ 40 would help but fear to get the bloody lean hang after steep climbs
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
