Old 07-12-2021, 06:07 AM
Gez Gez is offline
Riding sand at the moment.
Temp was 12-15degs.
MJ: 172
PJ: 42
Needle: NEDW clip #2
Having changed from 175mj to a 172mj made a massive difference, bike feels like it's got nitrous now in the top half of throttle. Also runs nice and clean.
I have bought a Beta 200rr that will become the bush bike now so I can devote this Gasgas to wide open sand etc.
Old 02-20-2022, 04:51 AM
FloGasGas FloGasGas is offline
Hello from France,
GasGas EC 250 converted to 300 - 2012
Main jet: 172
Pilot jet: 38
Needle: NECH
Clip position: 1 from top
airscrew: 1.75 turns out from seated
Throttle valve/slide = #7
Gas: 98 octane gas
Mix: 1.5% 100% synth?se oil
Altitude: 300 to 1100 meters
Modified original cylinder head, squish 1.3 to 1.7mm close to the center of the piston.
RV is now 14,3:1 (13,2:1 stock)
Stock exhaust
Old 02-22-2022, 04:23 PM
tomatoe333 tomatoe333 is offline
Moved out to Arizona, took a while to get a good jetting setup here.
Bike: 1999 EC200. Original PWK 38 AS-I carb.
Altitude: 2000-3000 feet (Phoenix area - New River, Wildcat, Mile Markers, etc.)
Temperature: 50-90 F. Generally low humidity, even on cooler days.
Main: 172
Pilot: 42
Needle: R1470M, 4th clip
Slide: #7
air screw: 1.5 turns out
Bike pulls clean and crisp off the bottom, though it's a little lean on overrun. I might try a 45 pilot and a little more air screw to clean things up on colder days.
I'm running, pretty consistently, 1 step leaner settings out here than I was at sea level on the east coast. And that goes for every bike in my stable, not just the GG. The dry air and the elevation seem to make a difference.
Old 02-23-2022, 07:29 AM
Biff's Avatar
Biff Biff is offline
Bike year & model = 2013 EC300
Temperature (degF) = UK!
Elevation (feet) = sealevel - 1000ft
Main jet = 175
Pilot jet = 42
Needle & notch = N3CJ 04 CLIP 2
Air screw setting = 1.5 TURNS
Results:
Clean all the way through - approx 9 miles per litre of fuel
Old 04-09-2022, 01:21 AM
yz250f2002 yz250f2002 is offline
Originally Posted by Doc Brown View Post
New favourite setting!
GasGas EC 300 - 2019
Main jet: 172
Pilot jet: 40
Needle: NECH
Clip position: 3 from top
Gas: 100 octane premium gas
Mix: 50:1 Fuchs Titan S100 Racing Oil
Altitude: 600 to 800 feet
@ 70 F
GP cylinder head
stock exhaust
9mm float height
Doc,
I was thinking the same setting for Sea level in UK. Is the setting good for WOT on mx tracks or stick with 175 main with NECH?
Old 10-18-2023, 03:36 AM
slylux slylux is offline
GasGas EC 200 - 2012 Six Days
PWK38 ASII (2 bolt cap)
Main jet: 168
Pilot jet: 35
Needle: N4DW
Clip position: top clip (leanest)
Slider: #7
airscrew: 1 turns out from seated
Mix: 50:1 Motul
Altitude: Sea level @ 20-25 C
stock exhaust
9mm float height
Crisp, easy to start, idles strong, Good 1/8 to 1/2 throttle usage (slow technical riding)
Plug a nice brown with minimal to no spoog
Old 01-30-2024, 06:14 PM
Wbdisco's Avatar
Wbdisco Wbdisco is offline
2011 EC 250e
Keihin 36mm (36 cast on cap)
168 Main
38 Pilot
CGJ needle 2nd position with shim( didn?t notice that the first time I pulled it)
Slide stamped 65
AS 1-1/8
Idle 7-3/4
600-2500 feet riding
Hot and humid southern riding in summer
Cool and damp in the winter
Brad
2011 Ec250
1982 Land Rover Santana Ligero
Old 03-30-2024, 09:53 AM
ec-txtr ec-txtr is offline
Default 2011 EC250 Six Day
Main jet: 175
Pilot jet: 40
Needle: JD Jetting Red
Clip position: 4 (almost richest)
Slide: #7
airscrew: 2 turns out from seated but doesn't really matter
Mix: 50:1 Klotz TC2
Altitude: <1000ft
FMF
7mm float height
I have had this bike for abut 5 years and it has always run well. Crisp and strong with very little spooge. It has the typical idle where it seems normal but then almost dies after about 15 sec. I have always used a 50/50 mix of 110 Turbo Blue and Shell 93 but started using straight pump gas last year and the jet block gasket failed and now its hard to get it back to where it was even with a new jet block gasket. Posting here before I try different slides and needles and will update if I improve things.
Old 04-28-2024, 10:46 PM
alang's Avatar
alang alang is offline
24 6days 300
50-90f
800' elev
Stock exhaust and 38mm carb
40 pj
As 1.25
NEDW#2
170 mj.
May tweak later as bike is really new
2022 Aprilia Tuono 1100 Factory
2023 BMW R1250RS
2024 Reiju 300 6 days
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
