#31
To completely disassemble the damper tube I'm guessing you undo this as well?
It's very tight and until I know if I should definitely remove it I won't. Also discovered that one of my cartridges is 'sticky' and the damper tube binds in the cartridge cap during the last inch of travel. The other cart doesn't do this and neither do the two spares I got from Simmo. Synergy is this the nylon bushing you were talking about that has too small an ID and causes binding? (located on the underside of the cartridge cap. Pain in the butt to remove, tiny little cir clip in a groove in the cap itself, I couldn't get hold of it so gave up for now. Is there anything other then the nylon/plastic bush in that cap? I haven't even looked at it yet but between the spring guide and cartridge cap there is a small round bush that sits in a recess on top of the cartridge. What is this? Should I leave it alone? Thanks again for any info. |
#32
Also, what's the best way of tightening the base valve?
The cartridge tool I had made will work but I have to remove the spring guide to fit it, does putting the fork back together and compressing it upside down (reverse of undoing the base valve) work? What torque do I tighten it to? |
#33
I'm no genuis here, but I'd assume that one side of the stack will control the compression, and the other side, as the fluid returns through the valve will be your rebound control. Probably more noticable on your base valve. I'm sure someone more knowledgable will guide you though..
Good luck with those internal snap rings. They were the most challenging part of servicing the shock! Theres a definite 'knack' to it. |
#34
I gave up on the snap rings because I was only armed with a small flat blade screwdriver. Trip to a tool shop tomorrow to buy a pick and I'll take them on again |
#36
What did you do it up with? Cordless impact driver same as used to undo it? That makes me a little nervous....
#37
I never put the Sachs back in the legs.
I went to Ohlins gold which uses an internal cup stop and the base plug. The TTX which is basically a gas strut, then threads back through the base plug the other way. It technically doesn't have a base valve stack, so I had to use an impact to rattle that in until I could get it to bite enough to get a torque wrench on it. As per Ohlins documentation. |
#38
While your tool appears to have let you into the cartridge, it fails to function when reassembling the base valve. You can rattle-gun it if you want, but those soft aluminum base valves didn't get any stiffer sitting on your bench.
#39
I have a 3/8" drive air tool that is pretty tame for use on a base valve with a good socket. Don't go at it with good 1/2" gun.
#40
I'll have to make up a tool from smaller OD PVC pipe I guess. Is there a torque value to do this base valve up or is it simply 'tight'? Twowheels I believe you had a fix for the mid-valve, can I ask what that was? |
Marzocchi 48mm CC Forks | SolidPerformance | Enduro Suspension | 334 | 01-08-2019 07:32 AM |
48mm Forks | Scramble Champ | "Wanted to Buy" & "Want To Trade" | 1 | 02-28-2013 07:09 AM |
48mm MRZ forks tool needed | Synergy-Seals | Enduro Suspension | 1 | 07-17-2012 12:41 PM |
Sachs 48mm Bushings | Jakobi | Enduro Suspension | 9 | 06-19-2012 07:18 PM |
new 48mm Marzocchi forks?? | Dave A | Enduro Suspension | 19 | 11-04-2011 07:48 PM |
