Old 01-19-2017, 07:39 AM
Anders's Avatar
Anders Anders is offline
Originally Posted by Scott Mc View Post
I was going to use the GASGAS triples and wheel, but the forks came with the Yamaha triples and I just happen to have a YZ front wheel so I am going to go that direction. Seems to be the simplest. Just trying to confirm the caliper and bearings.
The Gasgas Caliper mounts directly to the Yz caliper bracket. On my 06 200, I did the swap using 08 YZ250F forks and triple clamps. Used the GG wheel and caliper with the YZ axle and home made distances, and made 250mm brake disks for the GG wheels that I have.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 01-19-2017, 12:33 PM
(F5)'s Avatar
(F5) (F5) is offline
Yes Yamaha preplanned this move, however they could have precast some lumps for steering stops. The more YZs canabalised the better new sales. Foil hats everyone: IT'S A CONSPI. . , ,
So much better with SSS. Although for NZ conditions the YZ forks were too stiff and a revavle to KTech club specs did the biz. Just shim changes so was quite cheap.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 01-19-2017, 05:29 PM
CanGasser's Avatar
CanGasser CanGasser is offline
Yamaha might have the forks but not motor like the Gasser love this motor!
Current: 2007 GASGAS 300EC 2004 KTM 250 SX 2003 YZ450F
Old 01-19-2017, 05:31 PM
CanGasser's Avatar
That's excellent, I'm all set then thanks for everyone's help. Should be doing the motor rebuild this weekend and maybe the forks next weekend. Then strap on the studded tires!
Old 01-19-2017, 06:20 PM
(F5)'s Avatar
Search my head thread if you want the motor even better. Looking forward to the next ride as we are in summer. Sadly some rain forecast for the Sunday.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 01-19-2017, 10:14 PM
Zman's Avatar
Zman Zman is offline
I made the ssswap on my GG 2000 XC327 using the whole front end from a 2008/9 Yamihaha YZ450F. The only things I needed were a steering head bearing and HD furniture foot pads on the frame for stops. The springs were too light for my weight and dampening was too stiff for my riding so I decided to do my homework and learn how to revalve the SSS forks. It only took about 7 tries but I think I finally got it.
http://www.thumpertalk.com/topic/120...-input-needed/
Old 01-19-2017, 11:49 PM
_Hammy _Hammy is offline
Hi Zman, how did you fix the stops to the frame? To be honest, the thought of welding stops on is the main thing that's stopping me swapping over to the YZ triples
Old 01-20-2017, 02:06 AM
(F5)'s Avatar
Ahh mate don'tbe ssuch a pussy. Drill a hole, thread a bolt in there and cut a couple of blocks to trial. Then take them to a weldy dude with 20 bones easy as.
If dumb colonials can do it, surely you can. Same breeding stock and all that.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 01-20-2017, 04:31 PM
CanGasser's Avatar
Now I'm sitting here thinking of spring rates in the KYB SSS forks. For anyone that fitting them to a Gasser what spring did you end up with? I am 235 LBS without gear.
Thanks Scott
Old 01-20-2017, 04:33 PM
(F5)'s Avatar
Mine were YZ250 and seem OK after revalve. But other bikes may have different rates esp fat 4 strokes.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
EC300 2007 Front wheel not centered in forks Paynebrody Enduro Chassis & Body 1 01-12-2016 07:37 AM
EC300 2007 New forks stian Enduro Suspension 10 06-05-2014 10:37 AM
WTB Forks 02 GasGas XC 300 Mike Leach Parts 3 04-08-2013 10:46 AM
