Old 05-11-2015, 10:32 AM
5valve 5valve is offline
Took a different path today.
Visited two shops, got all the necessary parts for overhaul. Will be changing all seals, orings, even though they weren't leaking. Just a piece of mind.
Rod guide teflon bush 16x18x12 cost me 2.4 euros. It's dead standard.
Won't be changing valve bushing and oil/gas separator diphraghm guide. The latter is made from teflon only. It was measured OK.
They can produce it, but can't make a step cut, but rather at 45 angle.
Only problem occured with oil seal. I got the correct measurement of 24.5 OD, but it is firmer and has only one sealing edge.
If you look at OEM, it is rubbery soft and besides sealing edge, it has two extra grooves on the sliding area.
Non oem is also a bit higher at 5mm, but it doesn't affect its function even with original separating washer installed.
No matter, will be installing what I got, and if leaking occurs, will go for KYB seal, and have the seal head machined as per your advice.
I did all of this, because waiting time to get stock or aftermarket parts for sachs is unreasonable.
Service manual for Sachs rear shock MattR Enduro Suspension 9 10-19-2016 03:18 PM
New sachs shock baker Parts 4 03-25-2014 06:02 PM
2001 EC300 Ohlins Shock Help: Service and Setup krazy Enduro Suspension 7 11-24-2012 05:07 PM
