Old 05-02-2007, 07:13 AM
GMP's Avatar
GMP GMP is offline
Brian,
Spring length seems OK. Sorrry I didn't get back to you, I've been busy at night setting up my '07.
There should be a steel washer between the spring and the preload spacers, the last guy probably left it out. You should add preload, I think the fork will sag too much without any, expecially with the 4.0s. This can be done with the forks on the bike, bike on stand. Just remove the bars, loosen the top clamp bolts, and the fork cap. Put something under the front wheel to raise the fork caps and springs out of the fork for access.
Also consider you have a set of each 4.0 and 4.2, and can run one of each for a 4.1 if you choose to experiment.
Advice, How much? W8TSON General Discussions & Announcements 7 12-21-2009 03:30 PM
Need advice please gascanuck General Discussions & Announcements 2 12-15-2009 07:26 PM
Choices ?? Advice Fred1956 Enduro Engine - 2 stroke 10 11-20-2009 04:59 PM
Advice Please sbute General Discussions & Announcements 3 11-11-2009 07:04 PM
Jetting advice Silver Enduro Intake/Carburetion - 2 stroke 11 11-02-2009 04:12 PM
