Old 04-07-2021, 05:54 PM
gasgasman's Avatar
Originally Posted by 5valve View Post
Added orings behind seals on swingarm. Enough space, inner bearings needed just a little push inwards.
Its hard to source correct seals, but still easier than ordering OEM in these times.
O-rings are a better option than the seals.
Old 04-08-2021, 03:40 AM
5valve 5valve is offline
Yes, if you can anchor them. They tend to move outwards
EC 300 2008
EC 300 2018 GP
tenere 700
Old 04-09-2021, 02:46 PM
Has anyone increased size of the breather "jet", located left side power valve.
It seems pretty small hole, and of course it was clogged useless.
Old bike had bigger caliber, and I believe also bigger drain hole in cylinder wall.
Stock S3 piston ring ends are close together and travel through port, while vertex has them spaced, never leaving the wall.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 04-09-2021, 08:53 PM
Gasser Nate's Avatar
That jet is just a drain, the hose is clamped off from the factory make sure it is open. Never had a need to make it bigger.
Re the rings, most manufacturers have differing thoughts on them. Some have the gaps in constant contact with the wall, which I prefer, others have them passing over the transfer/boost ports. They are small enough that it isn?t an issue.
Old 04-11-2021, 12:44 PM
I did increase the breather hole to 1.5mm, as it was stuck with gunk. Tube is not blocked at the bottom, but joined into "Y" with other side breather, and then out.
Just had the head cut. Old piston squish was 2mm. With new piston was 1.75mm. Cut it to 1.24mm.
Since new piston is apprx 2/10mm higher, he said to use aditional base gasket, to correct port height to piston crown, as it results in 4 degree difference, which could affect top revs.
But I think, those engines aren't so picky, to really need an exact match to previous piston, since you can get them delivered new at very different settings, 200 rpm give or take.... Also exhaust port is perfectly lined up. From factory, one 0.5mm base was used. Will see how it behaves, and adjust if needed.
Head depth was also adjusted, have to measure compression.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 04-14-2021, 09:53 AM
gasgasman's Avatar
The small drain port in the power valve chamber will have to be drilled out too.
Just be aware that this can change the power characteristics of the engine.
Old 04-14-2021, 11:20 PM
Chamber hole still much larger then the increase I made, so will keep it stock for now. Cant see the drain affect engine. I see the small hole as an eco drippage preventer and floor stain after use minimizer. Bandage for overly rich bike when stock.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 04-17-2021, 11:32 AM
Breather bolt, LHS
Two options available -
- 0.5mm, called a devap., whatever that means, deeaporate??
- 3.0mm, probably stock non eco friendy, ment for direct-out hose routing, for free spill
So it is a tunable part, and both are speced for 2018 model, didnt check other years.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 04-18-2021, 07:10 PM
gasgasman's Avatar
The 3mm fitting is for the transmission vent- top right of the engine.
The .5mm one is for the power valve drain.
P-Tech protection for 2018 Gas Gas Gibnut Enduro Product Announcements 6 10-07-2018 06:23 PM
Tricks for holding down head o-rings? motogroove Enduro Engine - 2 stroke 10 05-14-2011 08:55 AM
Gas Gas 125 Trail Tricks/ RB Designs - Ride Report hasslbri General Discussions & Announcements 5 06-25-2009 11:16 PM
carb tricks again .... skid jackson Enduro Intake/Carburetion - 2 stroke 6 07-25-2008 01:33 AM
Carb tricks skid jackson Enduro Intake/Carburetion - 2 stroke 9 07-05-2007 12:30 PM
