Old 08-10-2014, 09:04 PM
Yeah I went into some depth writing but when actually doing the work its a piece of pie. The more times you can flip the cart and then get a small purge the better. The air hides around the outer edge of the piston. Its a poor design.
On the mid I'I've been running this
MV Comp (from piston)
12x.10 - Bleed
20x.10 (3)
18x.1
16x.1
14x.1
12x.1
11x.20 (2)
15x.15
16x.15
0.4mm float
Rebound (from piston)
20x.10 (2)
12x.10 - bleed moved down to crossover
20x.10
18x.10
16x.10
14x.10
12x.10 - from BV
11x 2.5 - collar
I'm thinking of addressing a few things on the rebound, and possibly opening up the float. I may pull the 12x.1 from the bottom of the comp stack and then slide it over as a bleed on the rebound. Or maybe I'll pull the 12 from the bottom of the rebound, move it to the bleed, and then drop a 14x.2 in at the bottom of the rebound to beef up the HSR substantially.
I'll have to do some more thinking before anythings in stone though. Still got 15 hrs before its due for its next service so will hold out till then.
Old 08-10-2014, 09:39 PM
n_green n_green is offline
Another point of interest, Simmo have you measured your ics spring? Mine is a different length to Jakes (same length as Natos??).
Can't remember how that affects things though? Jake help a brother out?
Current:
2014 Gas Gas EC300R
_____________________________________________
Previous:
2011 Gas Gas EC300 ELC
2004 KTM 300 EXC
Old 08-10-2014, 09:59 PM
I can't remember the length of mine, but maybe they are similar? I think 107mm rings a bell. I think you said yours were 100mm but I don't know how you accurately measured them if you didnt disassemble the ICS?
The PFP adj changes the preload on the spring, as does the length of the spring. The PFP has a range of around 10mm approx, and we all know what effect even a half a turn has on the fork action. Imagine the difference in feel between a spring of the same rate that has 7mm difference.
Old 08-11-2014, 01:52 AM
This time round I accurately measured them. They are 100mm. I pulled the pfp assembly apart to clean all the grease out of the comp clicker assembly.
Current:
2014 Gas Gas EC300R
Previous:
2004 KTM 300 EXC
Old 08-11-2014, 05:16 AM
I wish I could remember the length of mine. I'll check my notes in the morning. I may have wrote it down.
Old 08-11-2014, 05:51 AM
Based on my measurements the ICS spring rate is about 2.0 kg/mm.
Sound right?
Current:
2014 Gas Gas EC300R
Previous:
2004 KTM 300 EXC
Old 08-11-2014, 07:12 AM
Its the clearance where the bushing floats. So on the lower legs, there is a groove machined into the leg where the inner bushing locates. Not enough clearance and the bushing can bind up when the fork leg flexes.
ahh ok. so these are not like the sachs that rattle around in the tubes!?
2003 txt250 Pro
2013 Ossa 280i
Old 08-11-2014, 07:52 AM
Sound right?
Affirmative. Stock ICS is 2.0kg/mm - Nato had after market 1.8kg/mm installed with his. His BV was much firmer though.
Not at all. It still blows me away how much movement there is between the upper and lower on the Sachs, but with well over 300hrs on mine they have held up really well (with TTX carts). I installed them on the new bike for a ride early in the pic too. Could very happily run them on this bike.
Old 08-12-2014, 03:03 AM
Checked my notes tonight and I didn't document the length of the ICS spring! I should have wrote it down. I found some notes which I believe were the dimensions of Natos. His definitely floated around much more than mine. For some reason 107mm keeps popping to mind.
Old 08-12-2014, 06:42 AM
Fred1956's Avatar
Fred1956 Fred1956 is offline
on the zokes I had down from the 13 model, 107mm was indeed the length of the ICS spring
Fred Overstreet
2010 EC250 SixDays
2006 GasGas TXT 280 Pro
Slo Mo suspension Fred1956 Enduro Suspension 12 03-28-2014 02:46 AM
help with 03 200 suspension XR250R64 General Discussions & Announcements 0 09-10-2012 07:20 AM
same suspension ec 200 and ec 300? hannesd Enduro Suspension 3 05-13-2012 04:18 PM
EC 200 Suspension Gas Huffer General Discussions & Announcements 3 11-13-2007 10:34 AM
Suspension FAQ webmaster Enduro Suspension 12 09-18-2006 03:56 PM
