#41
03 ec250 hyde skidplate, cycra handguads, protaper contours "what? it seemed like a good idea at the time!" |
#42
I have also many different shims to play. I don't need to shuffle. May be you have a better commendation. With overdamped you think about the 3x 22x0.1 for the LS or the many HS shims. Can you explain why GG/Marz makes 3 stages. Or what is the advantage/ disadvantage for this 3 stage goofy setup.May be the forks sinks to much in the stroke? Quote:
Now I have 4.5 N/mm not tested or measured only see the specs like diameter s.o. I also have some 5N/mm. And looking for 4.8N/mm. Quote:
oil viscosity air gap spring rate seals preload
Husqvarna TE 300 |
#43
I've got .45nm springs and I'm 95kg in full gear. Mine are fine, but I don't do any MX. I have some .48nm springs if you need them, but they were to heavy for me.
The comp stack GMP has posted is very similar to what I'm running at the moment. I also run very little preload, about 2mm. |
#44
@GMP
I have a question to the total valve stack thickness The orginal BV stack has 1,75mm your recommendation only 0,95mm. What influence this parameter?
Husqvarna TE 300 |
#45
If you have more shims add a couple 11 x .2s or 12x .2s as a clamp (last shims) and to gain a little thickness. Thickness can vary quite a bit, as long as the last HS shim can bend around the clamp(s) some.
#46
Klausen
Have you fitted your new rebound piston rings yet? If you have has it made any difference with your clicker adjustments?
1998 EC250 07 Shivers 2T racing PV Spacer FMF Gnarly |
#47
But I think the rebound becomes a little bit better or to much may be. Last weekend we had a rocky 3h race over many little loose stones. The forks feels not very smooth in this stone fields more harsh. But I can't test it before and ride BV and Rebound screw in the middle. The original stack feels much more comfortable on this track. My be I have to slowly getting used to the stiffer fork? I heard that stiffer springs on the one hand not so comfortable in the low speed (not suspension - drive) area but on the other hand if I get faster they helps me to go faster with more feeling. What is the reason? Higher in the stroke? BV 22x0,3 Piston 22 x 0,1 22 x 0,1 21 x 0,1 11 x 0,1 22 x 0,1 19 x 0,1 17 x 0,1 15 x 0,1 14 x 0,15 13 x 0,15 11 x 0,2 11 x 0,2 Rebound 15 x 0,2 15 x 0,3 15 x 0,3 22 x 0,15 Piston 22 x 0,1 22 x 0,1 19 x 0,1 19 x 0,1 18 x 0,1 17 x 0,1 15 x 0,1 13 x 0,1 Last week I disassamble a KTM EXC 250 stock 2006 WP48 fork and compare it to a tuned WP48. My friend criticize also a harsh feeling in stone fields, before tuning. The most importend change was on the face of the BV piston this extra 2 shims. 23 x 0,1 13 x 0,1 And after this little change my friend feels much more comfortable one rocks and stones. My be I go to this BV stack for better "stone" feeling with also a strong LS damping. 22x0,3 Piston 22 x 0,1 13 x 0,1 22 x 0,1 22 x 0,1 21 x 0,1 19 x 0,1 17 x 0,1 15 x 0,1 14 x 0,15 13 x 0,15 11 x 0,2 11 x 0,2 Also I found a very great 18x0,25 shim at the bottom of the WP BV stack. Can anyone explain me the reason for this .
Husqvarna TE 300 |
#48
now I tried this basevalve stack
22x0,3 Piston 22 x 0,1 11 x 0,2 22 x 0,1 22 x 0,1 21 x 0,1 19 x 0,1 17 x 0,1 15 x 0,1 14 x 0,15 13 x 0,15 11 x 0,2 11 x 0,1 In mid/high speed range over large bumps the fork feels very safe. No bar shimming, and high in the stroke. Over rocks/stones not soft but comfortable. May be I need a little bit more stiffer MV for more low speed damping.
Husqvarna TE 300 Last edited by Klausen; 06-21-2010 at 10:34 AM. |
#49
now I found a good solution
I decrease the float to 1mm The LS damping is still to soft may be decrease float a little bit more ??? Rebound 15 x 0,1 15 x 0,2 15 x 0,3 15 x 0,3 18 x 0,1 22 x 0,15 Piston 22 x 0,1 22 x 0,1 19 x 0,1 19 x 0,1 17 x 0,1 17 x 0,1 15 x 0,1 13 x 0,1 BV 22x0,3 Piston 22 x 0,1 11 x 0,2 22 x 0,1 22 x 0,1 21 x 0,1 19 x 0,1 17 x 0,1 15 x 0,1 14 x 0,15 13 x 0,15 11 x 0,1 11 x 0,2 good luck
Husqvarna TE 300 Last edited by Klausen; 07-25-2010 at 11:28 PM. |
#50
Interesting, I may copy some of that................
Fork rebound question | Jeffro820 | Enduro Suspension | 8 | 02-08-2010 08:18 PM |
Rebound one side only? | chuz | Enduro Suspension | 0 | 09-20-2009 07:15 AM |
43mm WP rebound, help! | rupecopp | Enduro Suspension | 2 | 01-03-2009 11:01 PM |
Rebound shim recommendations (stiffer) | stay_upright | Enduro Suspension | 4 | 09-20-2008 02:20 PM |
Rebound adjustment on 04 & 05 MC and EC | FFRDave | Enduro Suspension | 4 | 01-23-2008 10:25 AM |
