Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Riding Techniques & Training
Riding Techniques & Training Increase Riding Skill, Physical and Mental Training, Weight Loss.
Old 09-21-2017, 06:38 AM
stay_upright's Avatar
stay_upright stay_upright is offline
Default Missing 2 mins per lap but front is at grip limit!
Finished a race on Sunday - a lot of flat grass and mud corners I would say corner speed plus entry and exit speeds will determine 95% of your overall time.
I had a decent front tyre on - used quite a bit for over a year but not severely worn and my corner speed is limited by its grip - I know i'm pushing it as I had ~30 little front end slides when cornering but I don't loose any time and didn't crash because of the slides so I feel I cannot go faster in the corners.
Braking I'd say I'm up there with the best I brake very hard very late - I overtook 10's of people on the brakes and never got overtook there.
Accelerating out of corners I can make a bit of time there when the going is grippy but my top speed is also good so only the acceleration out of the corner which is limited by fitness really.
The top riders (at this local event) are lapping in 11 min and me 13 min so they are a lot faster.. And they are faster round the corners.
I can run a new front tyre next time but doubt it's worth 2 minutes - so how are they cornering faster than me?
FWIW rear end grip was good - no issues there loosing the rear particularly and had a new tyre on the rear.
I also run tubliss and had 6 front 5 rear PSI so that should help grip quite a bit as well.
Thoughts?
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 09-21-2017, 07:22 AM
Zman's Avatar
Zman Zman is offline
Can you drop any total weight of the rider and bike?
Have you tried to drop the forks in the triple clamps (to lower the front end) to get more grip?
Old 09-22-2017, 04:20 AM
The only time I dropped the forks the front sort of tucked when riding uphill corners stood up so I put it back and have no more handling problems.
I think I need to try a new cornering style wider line and aggressive with the throttle after watching some YouTube clips which are quite good.
I can also try to focus on getting my weight further forward to stop the front sliding. Its a shame there were no photos from the last event to see what the difference in posture is between me and the faster guys.
'05 Gas Gas 300
'99 KTM 200
Old 09-22-2017, 04:57 AM
fullthrottle's Avatar
fullthrottle fullthrottle is offline
This^^ and lower tyre pressures if not rocky
06 EC250
Old 09-22-2017, 07:57 AM
Lower than 6 psi that I have already??
Ive been looking at this video quite a bit
https://youtu.be/ayvwni_Ex1I
I think if I want to get faster I need to change my technique to this which will be quite a big change and a lot to learn. I think I'm riding more like a road bike (rear wheel not spinning not drifting) with MX position (sitting on tank, leg out)
'05 Gas Gas 300
'99 KTM 200
Old 09-23-2017, 05:34 AM
Something that helped me was when you go from standing and braking to sitting for the corner make a conscious effort to sit straight on the outside edge of the seat it gives a lot more front traction than siting on the flat of your seat, also don't discount how much difference a brand new tyre makes over a year old tyre even if not really worn they still lose the edge grip and rubber gets harder.
06 EC250
Grip heaters on 2K-2 thejackrabbit Enduro Electrical & Wiring 4 01-19-2014 07:50 AM
Vapour Engine Temp and RPM Limit values? Hicksi Enduro Electrical & Wiring 1 12-20-2012 02:38 PM
Pistons worn out limit motohellrider Enduro Engine - 2 stroke 9 11-20-2011 07:22 PM
Stupid Question? Rev Limit? Jakobi Enduro Intake/Carburetion - 2 stroke 5 11-13-2010 05:36 AM
300 EC RPM limit? Hollywood Enduro Engine - 2 stroke 9 09-10-2008 07:59 AM
