Old 01-24-2018, 10:35 PM
chunkysoup's Avatar
chunkysoup chunkysoup is offline
Default 2011 EC300 Sachs stock spring rates??
I feel like I have searched the internet for hours, but I cant seem to come up with anything...
Does anyone know for certain what the stock spring rates are in a 2011 EC300 with sachs suspension front and rear???
Also for a 180lbs A-class rider who typically likes to run a little stiffer what would you recommend??
Old 01-25-2018, 05:32 AM
Anders's Avatar
Anders Anders is offline
Did you have a look in the user manual?
http://www.gasgasmotos.es/en/manuals...11_en.pdf.html
On page 35 it says:
Suspension spring
The standard spring is 5 SACHS; 5,2 ?HLINS
I cannot find anything about fron fork spring rate, though.
It's not listed in the parts manual either. But there, the spring rate of the Marzocchi fork is listed as "MUELLE K=4.2 / SPRING K=4.2"
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 01-25-2018, 09:51 AM
chunkysoup's Avatar
I saw the rear spring that said 5, but I've also heard contradictory statements about that. I also didn't find anything at all in the manual about front spring rates.
Old 01-25-2018, 01:14 PM
webmaster's Avatar
webmaster webmaster is offline
Administrator
You can measure the dimensions of the spring in order to determine the rate - and count number of coils. You can find calculators on-line...
I would do this regardless of what you find on the internet....
Old 01-26-2018, 01:21 AM
i seem to remember standard for spring being .42
@twowheels should be able to give an accurate answer
2003 txt250 Pro
2013 Ossa 280i
Old 01-28-2018, 01:29 PM
chunkysoup's Avatar
I'm trying to figure out what came stock in this bike. I already know the spring rates that are on my bike. The problem is I have super heavy springs in it for my fat butt. I just picked up a new 2018 so I'm trying to set this thing up close to stock or a 180lbs rider so I can keep it as a spare bike for my friends to ride.
2006 EC300 Forks and Spring rates motopsycho87 Enduro Suspension 1 01-02-2014 05:16 PM
Spring rates EC300 -05 SGM Enduro Suspension 2 11-29-2012 11:55 AM
07 ec 250-300 stock spring rates widebear Enduro Suspension 4 04-29-2009 04:49 PM
07 EC300 Stock Spring Rates? cladoo Enduro Suspension 8 04-16-2007 03:43 AM
Spring rates? moto520 General Discussions & Announcements 2 02-10-2007 05:20 AM
