Old 12-16-2011, 04:26 PM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
Default Compression valve(nut) on the bottom of a marzocchi 45?
The bike is an 07 Ec300 with zoke 45s .
I was just wondering if anyone had a spare compression adjuster valve.
This is the 21mm nut which houses the compression adjuster clicker.
I have managed to strip the nut and need a new one.
It is the right side fork leg.
Can anyone help me out????? please?
Cheers Mark
Old 12-16-2011, 07:15 PM
GMP's Avatar
GMP GMP is offline
How bad? You can try a 13/16" six point spark plug socket, its a tight fit on a 21mm nut. Grind the lead in taper off the end for more contact area(a trick Les taught me). Use a pneumatic impact tool.
Old 12-16-2011, 07:20 PM
wence's Avatar
It is pretty rounded now Glenn.
I was using a rattle gun to undo it and it was obviously locked in good.I thought I had got it undone until I realised it was actually spinning and rounding the nut instead.
I was hoping I could buy one off of someone as I want to fix it before I move it on.
Cheers Mark
Old 12-17-2011, 02:42 PM
wence's Avatar
Anyone????
Old 12-17-2011, 09:24 PM
Idahocharley Idahocharley is offline
Can't help with the compression adjustment nut piece other than offer advice for the future.
Most sockets have a beveled "lead-in edge". To maximize the engagement of socket to soft aluminium nut grind the "lead-in face" off the correct size socket. You will then have full engagement of the socket to the available alumium nut surface which minimizes the chances of rounding the nut. This is a tip applicable to KYB, Zokes, WP and other forks also.
Old 12-17-2011, 09:42 PM
wence's Avatar
Thank Idaho,
Hopefully this will help others also.
Cheers Mark
Old 12-18-2011, 12:48 PM
STM Suspension's Avatar
STM Suspension STM Suspension is offline
I'll check with relevant sources on Monday- Feel free to give me a call if I don't get to posting.
Dave.
www.STMsuspension.com
(970) 682-2071
Old 12-18-2011, 12:50 PM
wence's Avatar
Thanks Dave, wiil do.
Mark
Old 12-19-2011, 11:56 AM
In the process of checking... Marzocchi USA is checking with Italy- and I'm checking with the last people they sold some to- although it was 18 months ago.
Dave.
(970) 682-2071
Old 12-19-2011, 12:33 PM
wence's Avatar
Much appreciated Dave
Thanks again ,
Mark
loose bottom marzocchi cap noobi Enduro Suspension 2 06-06-2010 07:48 PM
Marzocchi 45mm mid valve check plate stay_upright Enduro Suspension 10 04-02-2010 12:37 AM
Base valve pistons Marzocchi Shiver 45 Klausen Enduro Suspension 4 03-30-2010 06:05 AM
Compression adjustment Marzocchi 45 vavido Enduro Suspension 3 06-01-2008 06:44 PM
