Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 05-07-2022, 12:45 PM
Moto7man Moto7man is offline
Default 1993 Honda XR 250 R Full Restoration
Another build coming along. I was wanting something more simple for extremely tight wooded single track. Low seat height, air cooled no radiators, smooth power, low maintenance and super reliable.I have had the YZ400 F, CRF 450s etc but I am really a two stroke guy so I am not so sure how this is going to work out.
Here is the old girl, she has been in storage for a long time. She turns over but won?t start. She has spark,fuel but the compression is too low,50 PSI per my gauge. So, I am going to start by pulling the head,cylinder for inspection, then send out head,cylinder to be bored for a new Wossner piston and all new Honda gaskets.I think the subframe and foot pegs are a little tweaked as well.Yikes, look at that stock silencer?. it?s as big as a boat anchor.
―Comedian Lewis Black
-Unknown Sardaukar
Old 05-07-2022, 06:15 PM
(F5)'s Avatar
(F5) (F5) is offline
I do enjoy your restos. I might struggle with the subject matter having valves and cams, but will see the transformation as what it is I bet.
RM still looks great lurking in background.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 05-07-2022, 08:08 PM
Thanks! I am struggling with the valves and cam stuff too.
-Unknown Sardaukar
Old 05-07-2022, 08:17 PM
Ok, I per her at TDC per the Honda Manual and removed the valve cover confirmed the timing marks on the cam sprocket were lined up. Here is a picture of the inside of the valve cover, everything looks good. She looks really clean inside, no metal, oil had drained out clean.
Here is the head at TDC, It?s very clean, I have to check the valve adjustment, .1 mm on intake and .12 on the exhaust.
-Unknown Sardaukar
Old 05-07-2022, 08:31 PM
I went ahead and removed the sprocket cam bolt, then rotated the crank 180 degrees and removed the other sprocket cam bolt, then removed the cam sprocket and the cam shaft and bearing noting that the sealed side of both bearings face outward.
Everything going along well and I removed the head bolts and head.
The piston didn?t look too bad, it is a Honda KT1, but I don?t see an indication if it is a std, a .25 or a .50.
-Unknown Sardaukar
Old 05-07-2022, 08:37 PM
Here is the piston,
Side shot of the cylinder,
This is where we are so far, however I have a problem, I have removed all the head bolts without a problem, it is a mix of 12mm and 8mm but I cannot break the cylinder loose. Does any one have any ideas?
-Unknown Sardaukar
WTB 1993 Honda XR 250 Frame Moto7man "Wanted to Buy" & "Want To Trade" 9 05-28-2022 10:10 PM
84 RM 250 E Ground UP Full Restoration Moto7man All Other Bikes... 212 07-03-2019 09:01 PM
1993 gas gas trials 250 r1chard06 Trials Engine 1 01-10-2019 10:15 AM
Gas gas trials 1993 upside down forks r1chard06 Trials Suspension 0 01-09-2019 02:11 PM
umm video of my racing the 1993 RM 250 *DANGER wheelie Pictures & Videos 2 09-20-2012 08:49 PM
