Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Product Announcements
Enduro Product Announcements Announce new gasgas enduro products here - Vendors Welcome...
Old 01-05-2023, 08:55 PM
gasgasman's Avatar
Default Oil bathed starter upgrade kit
CPD Direct now has an oil bathed starter upgrade kit available.
Item on the left is the power valve upgrade kit.
https://cpd.spareparts.cloud/img/car...g?w=1200&q=75&
Old 01-10-2023, 03:28 AM
ditezz ditezz is offline
The kit is very expensive and unnecessary .Just silicon up the bottom drain hole ,put in a breather, fill with 70-90 ml of light fork oil .No need for a new stator .The existing operates fine covered in oil
Old 01-14-2023, 11:38 PM
farmerj's Avatar
farmerj farmerj is offline
Right, you don't need this kit for the oil bath, you can do that for basically free.
But if you're having trouble with your starting system, this would upgrade to improved gears/bearings/bendix.
I'm interested in the stator - does anyone know how much the new bikes put out? I'm trying to run a light and grip heaters, each at 35W. The system should do 70W, I think - but it's not enough. On my 2018 XC 300 the charging system can't keep up.
Is the system on the newer bikes upgraded?
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 01-15-2023, 08:00 PM
Same as 2019 ec 300 ,70-75w.Trail tech make high output stators for KTM's As they share the same kokusan ignitions as the Spanish Gasser /Rieju , Im assuming you could use one of these .Need to do some homework though to ensure fit
Old 01-16-2023, 01:20 AM
Anders's Avatar
Anders Anders is offline
Jeff
If your light has a hi/lo possibility, you could do like I did. I have 50W lights with a low power / dipped beam possibility and heated grips with two powwer levels on my EC200. I have a couple of switches, giving me one of the following
  • full light
  • full heat
  • low light / half heat
  • off
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 01-16-2023, 01:37 AM
(F5)'s Avatar
(F5) (F5) is offline
If you trawl the Adventure bike sites, they probably have the Skinny on LED headlights, perhaps you can get a low current draw that is acceptable lumens? Make the most of your watt budget, what what!
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 01-18-2023, 06:45 PM
Neil E. Neil E. is offline
farmerj,
What voltage are you running them on? AC or DC? If DC you will have some issues. A low consumption headlight light is about all you can add on DC. If AC you should have no problem. All that will happen is that your headlight will dim a bit when the grip heaters are on.
I ran grip heaters on AC wired at full power only, for the past 10 years. Still on the same Ballistic brand lithium battery. My LED lights on high setting (DC) would run the battery down after about an hour and then I'd need to use the kickstarter. Not an issue because I didn't do very much night riding. I kept the LED headlights on low setting during the day and had the grip heaters turned on; no problems with battery charging. The usual riding time for me is from 5-6 hours (not including breaks).
If you add in a low setting for the grip heaters, they should work fine. You could also leave the headlight off while the grip heaters are on high, then change to low heat and turn on the headlight.
Ideally the battery should only be used for the estart.
2011 EC250E
Fork upgrade rbm33 Enduro Suspension 7 11-11-2023 08:18 AM
WTB 05>11 EC upgrade kit Nc30joey "Wanted to Buy" & "Want To Trade" 1 12-17-2018 03:40 PM
Headlight upgrade? Jtl13 Enduro Electrical & Wiring 9 07-07-2017 05:41 AM
Ohlins TTX upgrade Berkyboy General Discussions & Announcements 14 10-23-2011 07:59 AM
Bulletin Board Upgrade... webmaster General Discussions & Announcements 0 08-27-2006 09:46 PM
