Old 07-25-2010, 04:51 PM
bchatt's Avatar
bchatt bchatt is offline
Bronze Level Site Supporter
Glad you found a good solution. Are you using the 7.5 wt oil with this shim stack?
Barry
07 EC250
Old 07-25-2010, 11:35 PM
Klausen Klausen is offline
you have to know that the SAE weight system has a very broad and vague viscosity range and does not even cover the viscosity range that most quality motorcycle suspension systems require.
look post #16
yes I use finally a 7,5 but this is a mix 1:1 Motul Expert
SAE 5 and SAE 10
this viscosity is near the Marzocchi fork oil of 26,1 cSt@40C
good luck
my springs 4,5N/mm with 5mm preload
Husqvarna TE 300
Old 08-01-2010, 06:12 AM
Gasgasogeros Gasgasogeros is offline
Default shims
hi klausen where can find the shims like you setup
best regards
GasGas EC 300 2004
Old 08-01-2010, 08:43 AM
best regards
I thinks this setup don't work for you 2004 Shiver 45 forks.
I believe you have different pistons and no mid valve only a check plate.
A have a 2006 Shiver 45.
A good dealer in Greece can sell you this shims.
I can also offer you this shims. 1,80€ per shim is fair I think + P&P
Bye
Husqvarna TE 300
Old 08-15-2010, 03:51 AM
Rebound
15 x 0,1
15 x 0,2
15 x 0,3
15 x 0,3
18 x 0,1
22 x 0,15
Piston
22 x 0,1
22 x 0,1
19 x 0,1
19 x 0,1
17 x 0,1
17 x 0,1
15 x 0,1
13 x 0,1
BV
22x0,3
Piston
22 x 0,1
11 x 0,2
22 x 0,1
22 x 0,1
21 x 0,1
19 x 0,1
17 x 0,1
15 x 0,1
14 x 0,15
13 x 0,15
11 x 0,1
11 x 0,2
4,5N/mm spring
1mm float
7,5W Oil
5mm preload
110mm air
when I land after a large jump in the flat or in deep sand bumps
the forks feels to stiff at the end of the level
what can I do?
the fork use the full level (I use cable tie)
Husqvarna TE 300
Old 08-15-2010, 10:54 AM
nick790's Avatar
nick790 nick790 is offline
Are they bottoming out? Mine does it on MX tracks. I live with it because I like the way it works in the woods. Maybe decrease the check valve float??
Old 08-16-2010, 10:38 AM
I don't think so. I can jump very far no bottoming.
When I jump and land first with the rear wheel and the hard with the front wheel it feels very harsh.
I believe the the LS damping will be to soft after this for me - at the moment I would prefere some more LS
Husqvarna TE 300
Fork rebound question Jeffro820 Enduro Suspension 8 02-08-2010 08:18 PM
Rebound one side only? chuz Enduro Suspension 0 09-20-2009 07:15 AM
43mm WP rebound, help! rupecopp Enduro Suspension 2 01-03-2009 11:01 PM
Rebound shim recommendations (stiffer) stay_upright Enduro Suspension 4 09-20-2008 02:20 PM
Rebound adjustment on 04 & 05 MC and EC FFRDave Enduro Suspension 4 01-23-2008 10:25 AM
