Old 07-24-2009, 02:59 AM
stay_upright's Avatar
stay_upright stay_upright is offline
Default Does anyone know how the compression release works?
the hole type thing in the cylinder to ease starting....
I can understand a 4 stroke has either manual (released after starting) or auto (releases at an engine speed above cranking) but how would a 2 stroke compression release work? Surely it must have some mechanical components to stop the release of air with the engine started...
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 07-24-2009, 10:37 AM
gasgasman's Avatar
It is "controlled" by piston velocity.
While kick starting, the piston is moving slow enough to allow some blow-by.
Once the motor is running the piston is passing by the port at a rate quick enough that there is not enough blow-by to affect the compression.
Quick Release seat biggstr6 General Discussions & Announcements 17 11-10-2010 05:36 PM
Gas Gas Press release gasgasman General Discussions & Announcements 0 03-24-2009 06:12 PM
GasGas Press Release Mark Berg - CPD General Discussions & Announcements 15 11-23-2007 09:16 AM
04 300 fork kit - Pivot Works bocoz702 Enduro Suspension 2 02-12-2007 08:24 AM
300xc what gearing works best?? Dingoe Enduro Chassis & Body 6 02-05-2007 03:47 PM
