Old 12-30-2019, 06:42 PM
GasGas's Avatar
GasGas GasGas is offline
Default Spring dimensions KYB 18/19
Can anyone confirm the correct spring dimensions for the 18/19 KYB suspension?
2018 EC 300
Old 01-01-2020, 03:36 AM
There are 12 different springs available for the Gasgas 300 EC 18/19. If you ask for dimensions what do you exactly mean. Wire thickness, diameters. lengths?
I can give you the above mentioned dimensions for every KYB spring available. I need toknow which springs you run (N/mm). Or, if you PM me your e-mail I can send you the KYB parts catalogue 2019 and you can look at all the dimensions there.
Or maybe this can help: https://www.teknikmotorsport.com/com...as/ec300/2018/
The standard springs are front: 4.2N/mm rear: 52N/mm (source: 2019 EC 300 owners manual )
Old 01-05-2020, 01:52 AM
I?ve got a stick spring at home I can measure too. I used a spring from a WR450 in mine. Same dimensions except for the length, it was 10mm shorter, but easily taken up by the preload collars.
Old 03-01-2021, 08:53 PM
farmerj's Avatar
farmerj farmerj is online now
In case anyone is searching for this info., I just measured mine at 43mm x 454 mm.
I had called Cannon Racecraft and their book said 470mm long (that's not right).
I believe these GG springs are the same dimensions as the YZ 250.
FYI,
Jeff
BTW, Doc mentioned spring rates above. If you're a bit new to suspension like me, recognize that there are two units of measurement used - and a conversion calculation needs to be done.
For instance, the GG Manual states 4.2N/mm front, 52N/mm rear as Doc correctly indicates. But that is NOT Kg/mm, which is another common measurement. I purchase a 5.4Kg shock spring, but the stock 52N/mm = 5.3Kg/mm. So I didn't really increase the spring rate by much. Lesson learned!
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
EC125 springs dimensions doutsh Enduro Suspension 0 06-11-2015 06:29 AM
Footpeg Dimensions Neil E. Enduro Chassis & Body 16 10-15-2014 08:56 PM
JD needle dimensions BryanMcc Enduro Intake/Carburetion - 2 stroke 6 03-07-2013 07:10 PM
Hebo fatbar dimensions? Leon_gasgas Enduro Chassis & Body 5 11-25-2008 06:01 PM
'07 radiator dimensions GMP General Discussions & Announcements 6 03-26-2007 09:48 AM
