Old 11-04-2021, 02:50 AM
JAD JAD is offline
Default Marzocchi Shiver 45mm bottom nut?
Hi all, I am about to service my forks and just want to try and find out what the nut on the bottom of the forks is for.
It has a small adjuster screw in the middle which I guess adjusts rebound but what does the big nut do? Do I need to loosen it before dismounting the forks?
Does anyone have a link to the service manual for these forks?
Thanks in advance.
John
Old 11-05-2021, 03:27 PM
JAD JAD is offline
Update: Just for information...
Brandon sent me the the Shiver 45 manual (many thanks!) and I have worked out that the bottom nut releases the compression valve at the bottom of the fork BUT you need a special tool to insert down the tube and stop the whole thing turning so don't just plonk a spanner on try to undo it! I left well alone.
The forks are not too bad to service and the correct amount of oil is 610ml
My forks only had 300 ml (must have been leaking for a while) and it was a dark grey colour which I believe indicates that the bushes have worn a bit.
All good now.
Thanks again to Brandon.
Marzocchi 45mm shiver top nut Dan Enduro Suspension 3 08-03-2021 12:28 AM
marzocchi 45mm shiver johall865 Enduro Suspension 0 12-28-2014 06:55 PM
wtb marzocchi shiver 45mm mbogage "Wanted to Buy" & "Want To Trade" 7 04-06-2014 09:46 AM
wtb marzocchi shiver 45mm mbogage Parts 1 01-12-2014 09:21 PM
Marzocchi Shiver 45mm piston mcnut Enduro Suspension 7 01-15-2012 08:40 AM
