Old 03-02-2021, 03:57 AM
Anders's Avatar
Anders Anders is offline
Originally Posted by farmerj View Post
Hate to start a new thread for this question -
If you remove the KYB fork Base/Compression Valve (say, to play with shims & valving) do you need to bleed the cartridge when you put it back?
Or can you just remove handlebars, unscrew Compression Valve, and just screw it back in when done making adjustments?
Jeff
Similarly, when I remove the cartridge to replace fork springs, does it need to be bled before replacing?
The base/compression valve is inside the cartridge. Hence, if you open the cartridge, as you say, "to play with shims and valving", you have to bleed the cartringe after filling it with oil.
There should be no need to bleed it if you didn't open it, which you won't do if you just replace the springs.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 03-02-2021, 08:32 PM
farmerj's Avatar
farmerj farmerj is offline
Thanks Anders, I appreciate that!
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
KYB SSS Valving Input Please Zman Enduro Suspension 67 02-10-2020 12:26 PM
Heavy springs and stock valving. FastFast Enduro Suspension 2 08-05-2014 08:26 AM
05 shiver valving jasont1532 Enduro Suspension 6 11-11-2012 10:40 AM
Sachs fork valving '10 300 Bailey28 Enduro Suspension 16 10-18-2011 08:43 PM
