Old 02-15-2011, 12:59 PM
husley's Avatar
husley husley is offline
Bronze Level Site Supporter
Default Swingarm/Linkage-how does it go back together
2010 300
Cleaned/regreased the linkage.
Question about the swingarm attachment point-where the swingarm, case and frame meet up:
The pins that the swingarm axle run through each have a 'head'. The head can either be inbetween the frame and the swingarm (outside of swingarm) OR inbetween the case and the swingarm (inside of swingarm).
Which side do they go on?
I found some torque values in the manual-any 'no-no's when torquing it all back together?
thanks
J
Old 02-15-2011, 01:21 PM
PEB PEB is offline
I am 99% sure they go with the flange facing in against the linkage tie rods. Thats the way I just put mine back together. I torque mine down as tight as I can get them with hand tools then again after each ride for a couple rides. The swingarm pivot also tends to lossen up a bit after a couple rides.
Old 02-15-2011, 02:04 PM
husley's Avatar
Default ah-ha!
Thats the term, "flange". thank you!
............and I think I have them backwards
Old 07-16-2011, 10:36 AM
ollie ollie is offline
late I know but yes the Flanges go to the inside. In my haste I put them in the wrong way and damaged the alloy of the swing arm where the outer seal goes. I filed it smooth and replaced the seal,just waiting on a new bush as the hardened flanged head was totaly destroyed.
ollie
Swingarm and Linkage Bearings blitz11 Enduro Chassis & Body 34 01-12-2015 03:41 PM
Two "Don't Miss" Races Back to Back twowheels Mid-West Forum 0 09-14-2010 09:11 PM
Linkage redrider7202 Enduro Suspension 1 05-12-2010 05:34 AM
Swingarm linkage/bearing kits gasIdaho Enduro Suspension 1 02-03-2009 01:29 PM
