Old 02-27-2014, 06:14 PM
Default Marzocchi 48mm CC Compression valve removal
Hi,
Wondering which brand everyones using? I know the size is the same as the 48mm KYB SSS however my racetech tool is a solid piece and can't accomodate the PFP adjuster, so here I am chasing another. Just curious which brand offers the most positive fit/clearance?
Cheers
Jake
Old 02-27-2014, 11:32 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
I bought mine from Ballards, it had the perfect indent from thr get go, 20 bucks I think.
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 02-28-2014, 12:01 AM
Any idea what brand? I've emailed Dave at Suspension Matters. Hopefully he'll be able to scoot one out Monday for me
Old 02-28-2014, 12:22 AM
twowheels's Avatar
Hi,
Cheers
Jake
RaceTech that I spun on the lathe to provide the necessary clearance.
Steven Beane #275
afterhourscycle.com
Old 02-28-2014, 12:34 AM
Simmo737's Avatar
It's anodized red, no markings, machined with the indent. Sorry can't provide more info. Def from Ballards.
Oz
1978 GT80 Yamaha
Old 02-28-2014, 12:41 AM
n_green n_green is offline
Hi,
Cheers
Jake
Ballards should be open tomorrow, they're usually ridiculously quick with postage too.
Just a service or a fiddle with the shims?
Old 02-28-2014, 01:29 AM
I'm going riding in the morning! Still got the 2010 model ready to ride so no rush chasing parts.
Definitely need a post break in service, but I think I'll at least take the time to record what the stacks are and then go from there. Probably want to add some more rebound to them (piss off the bleed shim).
I'm still tossing up if I want to up the spring rates or not. Pretty happy with the rear 5.4 rate. Might try and measure the rates on the fronts.
Old 02-28-2014, 03:30 AM
Ended up ordering one of these. About the same price as I would have got the ballards one for. Blows paying almost as much in postage as you do for goods, but what can you do. I just hope they have enough relief to still positively lock into the fork cap. If not I'll look at having it machined out some more.
Old 02-28-2014, 04:38 AM
Vindicator Vindicator is offline
Don't mean to be a party pooper but those look quite the same as the one I got from Motion Pro :
The inside isn't deep enough to accommodate the PFP adjuster. I had to order a custom machined piece on a local shop, problem solved .
Vindicator
'11 EC 300R
Old 02-28-2014, 05:13 AM
I checked the ballards website and theres looked very similar in depth also. I guess worst case scenario I'll drop it around an engineering shop and have them machine some out of it.
Marzocchi 48mm CC Forks SolidPerformance Enduro Suspension 334 01-08-2019 07:32 AM
Marzocchi 48mm 2nd service GMP Enduro Suspension 1 02-04-2013 04:16 PM
48mm MRZ forks tool needed Synergy-Seals Enduro Suspension 1 07-17-2012 12:41 PM
48mm Marzocchi warning! STM Suspension Enduro Suspension 17 03-22-2012 03:44 PM
Marzocchi special tool for tearing down fork? bergerhag Enduro Suspension 1 08-14-2007 08:42 PM
