Old 05-22-2017, 01:08 PM
rvktm rvktm is offline
Default 013 300 fr ttx rear mar 48 cc suspension set up help
iv now ridden the bike three times first was at a rutty gravelly sandy bovington felt to stiff so i backed the hs and ls right of on the ttx and the ls rebound and preload on the fork .next ride loamy sandy woodland not over used so nice going felt good if a little firm next ride tite woodland lots of tree roots far to stiff . im 75 kg no gear 52 rear 4,2 front std oil level . going to try 4.1 front 50 rear iv got the next softer setting chart for the ttx is that the way to go? not had time to service the inner cartridge on the fork thanks
Old 05-23-2017, 11:21 AM
Anders's Avatar
Anders Anders is offline
There is a long thread here on the Marzocchi Pfp 48 fork. It discuss adjustments and also different oil viscosities, shim stack changes etc
I suggest you start there.
http://www.gasgasrider.org/forum/showthread.php?t=11075
Sent fra min E5603 via Tapatalk
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
2013 rear suspension Malcolm Enduro Suspension 2 02-12-2013 03:06 PM
2013 GasGas rear suspension Malcolm Enduro Suspension 15 12-18-2012 06:26 PM
Rear suspension riding low and hard on a 07 ec 300 jarrodw Enduro Suspension 9 12-17-2011 04:37 AM
Rear suspension creaks Larsa Enduro Suspension 9 09-08-2011 10:16 PM
How many O rings on the rear suspension rocker stay_upright Enduro Suspension 7 01-15-2008 08:58 AM
