Old 12-16-2019, 01:10 PM
Originally Posted by TGM_OFFROAD View Post
If you are in the states check out rocky mountain atvmc. Swing arm kits are one if like 4 bike specific parts they actually sell for a Gasser
Ta TGM, I am in Europe, but found the parts over here.
Old 10-19-2020, 04:23 PM
Gez Gez is offline
Long shot but does anyone know whether the rocker arm bearings and the dog bone bearings are the same size? I've taken mine down for a re-grease and they're shot to shit. All the bushings look good but the cases and needles are dead. I'm guessing i can source these bearing fairly easily from a bearing shop along with the seals?
Old 10-19-2020, 05:52 PM
The parts fiche do not give bearing dimensions. I think the rocker and dog bone bearings are the same size
I will check the All Balls linkage bearing kit I have when I get home tonight. I will verify that they are the same size, and see if I can confirm dimensions for you.
I really hate using All Balls bearing kits as I think that they are cheap Chinese bearings, but I do not think that Pivot Works makes kits for the 2018+ models. It would be good to know if we can source a well made Japanese or German bearing for the linkage.
Old 10-19-2020, 06:19 PM
Gez Gez is offline
Good on you! That'd be great. Plan is to get some SKFs and seals to throw it back together
Old 10-19-2020, 07:32 PM
shawbagga's Avatar
shawbagga shawbagga is offline
Yeah they're the same size.
'18 Gasgas XC250
Old 10-19-2020, 07:33 PM
Rocker and dog bone bearing are all 20x26x16 mm cageless drawn cup needle bearings.
20YM2616
Old 10-19-2020, 09:04 PM
shawbagga's Avatar
20YM2616
Remember what swingarm were mate?
'18 Gasgas XC250
Old 10-20-2020, 02:58 PM
I think they are all the same except the lower shock bearing
Anyone considered making bushes out of vesconite to do away with this issue?
I fitted the synergyseals teflon coated bushes on mine and they lasted forever, but i suspect they had a bit higher friction, I also mostly rode dry weather. Vesconite should be more slippery - there are some good videos of it being used on dakar car suspension bushes
2003 txt250 Pro
2013 Ossa 280i
Old 10-20-2020, 05:39 PM
Gez Gez is offline
Got my old bearings out last night. I'm doing a run to the shop today, I'll make a parts list including seals when I'm done. Might make a good sticky?
Old 10-24-2020, 05:06 PM
Ta! Looking fwd seeing your list
Swingarm & Linkage Bearings Hulle Enduro Suspension 16 11-10-2017 06:16 AM
Ec250 linkage bearings Scotty97 Enduro Chassis & Body 4 01-24-2016 11:29 AM
Ec250 linkage bearings Scotty97 Enduro Suspension 0 01-17-2016 04:51 PM
'12 Linkage and swing arm bearings seitz331 Enduro Suspension 4 11-29-2013 06:59 PM
