Old 04-15-2010, 08:32 AM
nick790's Avatar
nick790 nick790 is offline
Originally Posted by moto9 View Post
Don't ignore the mid-valve...a lot of magic can be massaged out of it
I set the float at 1.5 mm but also used a light (10) face shim.
And while your at it, think about the rebound stack... I had to stiffen up mine quite a bit to cancel out the pogo effect.
I need to go even stiffer on the fork's H/S reb
Where are you measuring you 1.5mm float on your mid valve?
The .10mm face shim makes sense, I may try that
Old 04-15-2010, 11:17 PM
moto9's Avatar
moto9 moto9 is offline
Yes,
between the piston face and the first shim or face shim...I used a feeler gauge and guesstimated as close to 1.5mm as I could without any deflection of the shim.
I trail only, logs, roots, rocks, all woods and jungle stuff...no mx.
That's why I can get away with a softer valving setting.
Did I mention I did go to stiffer springs front and rear, so that I can get the bike to ride higher in the stroke.
Old 04-27-2010, 12:51 PM
darren's Avatar
darren darren is offline
Your lucky i telephoned marzzochi today they could not help at all with the stock shim set up. They advised me to speak to GG uk.
I didnt bother cos GGuk would only tell me to speak to Marzzochi. ho hum
1998 EC250
07 Shivers
2T racing PV Spacer
FMF Gnarly
Old 05-03-2010, 02:59 AM
Radbuster's Avatar
Radbuster Radbuster is offline
Try calling Steve Plain, they do a lot of suspension for GG's in the UK.
www.steve-plain.co.uk
mint 2008 EC200. Earlier bikes: Husqvarna WR125 '12, Husaberg FE450 '10, Sherco 4.5i '05, EC300 '07, YZ450 '03, WR250F '01, WR400F '00.
anybody know of a good setup for LTR kit on an 03 Ec250? dank Enduro Intake/Carburetion - 2 stroke 5 02-27-2010 02:43 PM
Marzocchi experts - help with 08' EC250. nick790 Enduro Suspension 1 05-09-2009 02:41 PM
05 EC250 Marzocchi stock shim arrangement ? ferguscawley Enduro Suspension 10 01-10-2008 07:49 AM
450 Timing setup Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 3 11-04-2007 03:24 PM
Need help with EC 300 setup Texas Gasser Enduro Suspension 4 05-24-2007 06:21 AM
