Old 06-25-2013, 11:12 AM
Fabry Fabry is offline
Default Crank Remover and Crank Installer tools for EC250
Can anybody please point me to some good Crank Remover/installer tools that works with Gas Gas 2 strokes?
Old 06-25-2013, 12:06 PM
Tusk (rmatv) sells one, however I never required one when I did my bottom end. The cases split easy enough (once all the bolts are out). If the crank doesn't come out a few taps with a plastic/rubber mallet moves it easy enough. For installation I simply froze the crank with some dry ice and it dropped right in.
Old 06-25-2013, 12:07 PM
pscook's Avatar
pscook pscook is offline
I didn't have to use any install tools, are you having issues? I know that motion Pro makes a very nice press and puller, they are affordable and pretty stout. But, again, I haven't had any issues installing a crank into the bearings if you freeze everything before installation.
Phil
(New bike pending...)
Old 06-25-2013, 03:37 PM
Originally Posted by pscook View Post
I didn't have to use any install tools, are you having issues? .......
I didn't start the job yet I'll like to line up with all I need (or may need) before start, this is only my second Crank rebuild i did an old XR250 once and it wasn't easy...
Thanks for the tips.
Old 06-25-2013, 06:36 PM
pscook's Avatar
Check out Jakobi's rebuild thread here, he sorted everything out pretty well (two or three times in places ).
Phil
Old 06-25-2013, 07:24 PM
True that! That was my first ever bottom end. Learnt a few things.. Next one will be a walk in the park.
gas gas ec 200 crank chinesegav United Kingdom 5 11-27-2012 06:49 PM
Crank it up! Rick Pictures & Videos 2 04-09-2011 12:36 PM
2007 EC250 Crank Bearing? BIG TOOL Enduro Engine - 2 stroke 9 11-23-2007 02:47 AM
