Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Riding Techniques & Training
Riding Techniques & Training Increase Riding Skill, Physical and Mental Training, Weight Loss.
Old 08-08-2018, 06:13 PM
BLD's Avatar
BLD BLD is offline
Default I Lost My Front Brakes And Found Some New Skills!
Have you ever lost your brakes on a steep, loose downhill? I did a couple days ago and I learned a lot! This seems like the most appropriate place to post this...
I was riding with some friends Sunday and lost my front brake due to an air bubble in the line, on a steep, silty/rocky downhill. We were only a part of the way down the canyon and it was our first ride of the day, so we headed back to bleed the line. By the time we got up the hill my brakes had come back some, and we could not bleed them out without draining the master. I could not open the master due to a stripped phillips screw on the cap to do a proper flush either. We were hours from home and I did not want to pack it in...
We packed the 8mm wrench and set off again with the intention of bleeding the front once they faded again. Unfortunately we never got them all the way back. We only made a slight improvment overall. I did not have to pump them any more to get a response, but they went to the bars before they began to shed any speed...
Now for the fun part. Since we knew I had already made it down the worst grade with no front brakes, we headed back to the canyon to make it to the sandy wash at the river (fun spot to play if no one is camping). The second trip down was much better since I did not have to pump my front brake to get any response. I kept it in 1st, and learned how much I could let the rear slide and still maintain control downhill, so having a bit of front brakes made the second trip much funner. I was never very confident going down hills so this actually built a lot of confidence in what my bike can do while sliding downhill. In fact my only fall of the day was climbing a hill, and the brakes had nothing to do with it lol!
After the steep canyon ride we spent the rest of the day exploring new trails. I was very hesitant coming into blind corners, but eventually learned to use my rear brake more and managed to ride faster than I did previously with good front binders! I realized that my bike actually shed a lot more speed than I thought with engine braking and a little rear. This was like when I realized I was braking too soon at the racetrack on my R6... very liberating when you realize you have the traction to carry more corner speed!
Overall I am very pleased I stuck it out and altered my riding style to accommodate my mechanical failure. By not packing it in and learning to adapt, I learned a lot about my bike and myself. With that said, I hope to never again experience the panic that comes with your front brake going to the bar, with no response!!! I will be much more careful with my brake pads from now on when I remove my wheels for service!
Edit: I am done caring why my apostrophes always turn to question marks!!!...
Old 08-08-2018, 06:40 PM
AZRickD AZRickD is offline
A silver lining.
Old 08-12-2018, 06:28 PM
BLD's Avatar
BLD BLD is offline
You got that right AZRickD! Thanks to some good friends and a great hardware selection at the local big box store, I now have new fluid in the lines and all the air has been squeezed out! I can hardley believe they had the exact screws I needed in a multi-pak. See attached pic below if you have a stripped screw in your Nissin front master (2013 XC300). BTW I used an EZ out to pull the stripped screw.
File Type: jpg 606B815B-22C6-47AC-8DE2-CDB3EA73C907.jpg (125.3 KB, 16 views)
Old 08-13-2018, 03:42 AM
RBrider's Avatar
RBrider RBrider is offline
Thumbs up
Good job.
It took me a bit to get the front brake working well on my '01 XC200 after I purchased it, but it was well worth it. It is very strong yet smooth & easily modulated (I may have invented a word there) on big downhills.
RB
Old 08-13-2018, 02:04 PM
SS109's Avatar
SS109 SS109 is offline
I experienced the opposite once. I lost my rear brakes due to a defective set of pads which allow the friction material to separate. I trail brake as part of my normal riding technique so this was really woke me up as I was entering a high speed turn! I was way out from our staging area and rode it out. At first I was really slow as I'm used to using both and not having the rear felt completely foreign to me. However, as I rode, I got faster and faster until I was riding at a really good clip. It was nice to learn how fast I could go on the front brake alone but I don't wish to do it again!
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Front Brakes HoppyPoppy Enduro Chassis & Body 1 08-11-2017 09:54 PM
front brakes chchnick Enduro Chassis & Body 6 04-13-2015 05:31 AM
Cant get all the air out of my front brakes andykr87 Enduro Chassis & Body 20 09-12-2014 05:15 PM
2002 TXT Pro front brakes Lotus54 Other GasGas Bikes/Quads 0 03-11-2013 10:55 PM
Broke my Big Toe!!! front Brakes went out.. Scar13 Enduro Engine - 2 stroke 7 02-06-2013 10:58 AM
