Old 09-11-2012, 09:28 PM
70455 70455 is offline
Default 2001 xc250 linkage removal problem. ..trapped bolt
How should i remove the upper linkage bolt? It cannot clear frame.
Do the linkage to swingarm pivot plates need removal?
I need to press out lower shock bearing race.
Is there a method to remove thin trashed outer race? Cclamp and socket yielded ni results.
Tx
Old 09-11-2012, 11:39 PM
bergerhag's Avatar
You need to remove the swingarm. When it is removed, loosen the two lower bolts and the assembly can rotate backward, making it possible to remove the bolt for the main link.
Old 09-12-2012, 05:20 AM
Should i install grease fittings anywhere while its apart?
Old 09-12-2012, 07:58 AM
GMP's Avatar
GMP GMP is offline
The linkage is R&R as an assembly. You remove the swingarm as you should service that as well. Remove the chain roller as it will interfere with the left side link plate bolt. Loosen everything on the bike and remove. Service/regrease on the bench. Assemble hand tight as shown. Install on the bike by TEMPORARILY using the swingarm pivot shaft as guide without the swingarm. Tighten plate bolts and main rocker pivot. Reinstall chain roller. Remove pivot shaft and reinstall swingarm. Tighten lower shock mount and pull rod bolts.
No grease fittings. Use fresh orings and Moly Paste or Castrol Pyroplex Blue grease. Serviced properly these linkages are the most waterproof in the business. I go a full year between services and have original bearings in an '07.
Also, NO PRESSURE WASHER.
Old 09-14-2012, 11:43 AM
Swingarm shaft stuck. Pb blaster soaked 2 days and no budge. Impact hammer? Brass drift and socket with deadblow and sledgehammer dont work.
Old 09-14-2012, 11:48 AM
eff's Avatar
eff eff is offline
Keep at it. Have you tried loosening the other motor mounts?
2004 GasGas DE250
Old 09-14-2012, 11:50 AM
All motor mounts or just rear 2?
Old 09-14-2012, 12:58 PM
GMP's Avatar
GMP GMP is offline
Lay it on its side and support the frame on the floor in this area around the swingarm boss. This way you can transfer more energy to the pivot bolt without moving or damaging the frame. Impact hammer, bigger sledge, etc. Don't mushroom the end. Move it a little each way hit it with the penetrating oil in betweeen. Whatever it takes. Big mess.
Old 09-14-2012, 09:12 PM
Removed wheel from swingarm. Loosened motor mounts. Supported with wood. Used hf orange deadblow with drift. Realized that sledge is 20 minutes south of me and its late. Ill keep at it.
The shaft is seized in the cases, right? The arm rotates freely.
Old 09-14-2012, 09:40 PM
70455. In addition to all the tips and tricks you've been given start doing heat cycles with boiling water. Boil the kettle up and pour it all over the back of the engine case/swingarm and then return to sledge hammer method. Once its cooled repeat again.
I went through it with a yamaha recently and it took a few patient days working at it but it came good in the end.
Tags
linkage removal
Tight Linkage Bolt binsel Enduro Chassis & Body 5 03-18-2011 12:52 PM
Swing Arm Bolt Removal RPB111 Enduro Chassis & Body 5 12-28-2007 04:18 PM
