Old 02-14-2008, 01:11 PM
PEB PEB is offline
Default Athena rings
I messed one up last night and need a new set. Anyone know who has or stocks ATHENA rings for an 02 300 gg.
Paul B
Old 02-14-2008, 07:50 PM
Dave Dave is offline
I don't know if this info is any help, but the Athena piston kit I bought from Smackover had a Wossner piston. The ring set is marked with "S41316016" and "2835CD".
Old 02-14-2008, 07:52 PM
PEB PEB is offline
Thank you. I should have added that the rings came in an Athena kit but are stamped Wossner.
Old 02-15-2008, 10:54 AM
It appears that 2835CD is a current Wiseco part number for 72mm rings. Jim Cook had told me that the Wiseco rings wouldn't work in the Wossner piston, but maybe the opposite is true?
Old 02-15-2008, 11:45 AM
Grab the calipers out and find out.
Old 02-15-2008, 12:40 PM
PEB PEB is offline
Thanks to all who chimed in. I got them from Halls. Anyone who says GG parts are hard to get is full of it. Incidently the wossner rings are identical(according to my calipers) to the wiseco rings. By midweek I should have the bike back together with a fresh topend, nearly new 06 pipe, hyde combo, ltr mud guard,new levers and maybe white plastic. I sure wish I could find some white side pannels.
Paul B
Old 02-20-2008, 09:31 AM
widebear's Avatar
widebear widebear is offline
Banned
You did measure width and height? I locked up a kx motor by neglecting to take the critical width measurement, it was the Becks fault
Old 02-28-2008, 03:03 PM
rrguy's Avatar
rrguy rrguy is offline
I believe mine had a Vertex piston put in right before I got it. On the box it says: Ring 53010007200
Head O rings Highwayman Enduro Engine - 2 stroke 8 02-04-2010 08:43 PM
O-rings. Ud_luz Enduro Engine - 2 stroke 7 11-23-2009 06:14 PM
Putting in new rings 101racing Enduro Engine - 2 stroke 16 04-22-2009 01:21 AM
Rings steve Enduro Engine - 2 stroke 2 03-10-2008 02:36 AM
Piston and rings EC 300 brains Enduro Engine - 2 stroke 1 08-22-2007 12:11 AM
