Old 02-20-2010, 11:05 AM
dank's Avatar
dank dank is offline
Default anybody know of a good setup for LTR kit on an 03 Ec250?
I was refered to LTR from a friend, and before i get it i would like to have some idea of what i need to do with it to make it run they way i want it to.
i have an 03 ec250 and i would be riding in 30-90degrees F for enduros and hare scrambles. i want it to be smooth and as a novice rider i dont need it to go crazy under me either. so anybody that has data would be much appreciated. i would be running 50:1 Yamalube 2r. any help is appreciated
Thanks!
03 ec250
hyde skidplate, cycra handguads, protaper contours
"what? it seemed like a good idea at the time!"
Old 02-25-2010, 03:35 PM
GMP's Avatar
GMP GMP is offline
dank,
Where are you located and what is your altitude?
Do you actually have the LTR kit or needle? I ask this because LTR is no longer selling kits.
What I would suggest you do first is get a #7 slide, the '03s came with a #6. Of all my GGs the '03 was the biggest PIA to jet right initially and it was the only bike with a #6 slide. I swapped a #7 and it was much better.
Search this forum, there is a lot of info on the kit including mine from my '03 EC250. If you do not have an LTR kit, and want a quick solution, the JD Jetting kit (generic kit for PWK38AS carb) works excellent in the 250s. Other than that, get a DDK, DEK, and CCK needle and assorted brass and go play.
Old 02-26-2010, 02:22 PM
dank's Avatar
as near as i can tell they are still selling the ltr kit on gofasters. i am as green as they come as far as bikes. i didnt grow up around them and my girlfriend got me into them. her dad said that changing to an ltr kit would be a good idea. i was just wondering if anybody knew of a good setup for it. i live in mid western minnesota. as for altitude, i dont know that either, though i cant probably figure it out. i looked in the settings database thread and didnt find one for the 03 ec250. but if you've done it or you know of a good kit and settings it would be much appreciated! im planning on running enduro's and hare scrambles.
03 ec250
Old 02-26-2010, 02:25 PM
dank's Avatar
average elevation is around 1400 above sea level
03 ec250
Old 02-27-2010, 06:13 AM
seitz64 seitz64 is offline
Default set up
try cek middle jets above 50 f 42 pilot 178 main below 50 f 45 p 180 m this should get u close! if u have a heathy motor ! ltr needle with these jets is also close ! if it feels fat drop the pilot 1 size works for me ! have this set up in 5 bikes
Old 02-27-2010, 02:43 PM
dank's Avatar
alright thanks! ill see what i do, i may just run it like it is, for now until i get enough money to start tinkering. it runs ok, but theres alot of splooge and it doesn't run very well cold. but thanks! any other suggestions would be helpful as well!
03 ec250
Marzocchi setup help - 08' EC250 nick790 Enduro Suspension 83 05-03-2010 02:59 AM
Desert Setup PEB General Discussions & Announcements 6 03-24-2008 06:13 PM
450 Timing setup Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 3 11-04-2007 03:24 PM
Need help with EC 300 setup Texas Gasser Enduro Suspension 4 05-24-2007 06:21 AM
Good results for EC250/300 in Master Enduro test Leon_gasgas General Discussions & Announcements 3 01-26-2007 12:15 PM
