Old 08-09-2022, 07:00 AM
BMG BMG is offline
Default Code for 2018XC kyb shock top eyelet bearing
Hi,
Changed all my linkage bearings and bottom shock bearing but not the top hemispherical bearing in my shock. Put it all back together and there is still some play in the linkage set up. I can feel the top shock has some movement. Rather than buying the entire bearing kit, I just want to replace the bearing. When I had the shock out I couldn't see any numbers/letters on the hemispherical bearing. Does anyone know what the bearing code is so I can order one from a bearing shop. It's the factory KYB shock that comes with the bike
Cheers
Old 08-11-2022, 08:14 PM
Gasser Nate's Avatar
I believe it is a Yz250f part number. I had the Kyb catalog but my laptop died.
Sachs shock bearing Panagiotis Enduro Suspension 12 11-24-2022 02:37 PM
2018 KYB shock bearing eralha Enduro Suspension 9 10-31-2019 04:10 PM
ohlins shock bearing imsimon Enduro Suspension 7 12-12-2017 03:55 PM
rear shock bearing gassergrant Enduro Suspension 0 12-13-2014 11:33 AM
2011 SixDays 200 Shock Code twowheels Enduro Suspension 1 03-01-2011 06:56 AM
