Whay doesn't GasGas have an online Factory Service-Shop Manual and site like these? The shop manual below is 351 pages with labeled digital photos!
http://www.endurofactory.nl/pdfs/201..._250R-310R.pdf http://www.husqvarnafactory.nl/pdf/index.htm
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
Has anyone seen a current GasGas factory shop manual like these Husqvarna manuals? I'm curious because the factory and or the bigger dealers must have one, right???
![]() Quote:
The answer to that is no.
2013 GasGas 300 2004 GasGas 200 2011 GasGas 300 Ortonville Minnesota |
Guys, are there any published torque values for the fasteners used on the engine and frame? I'm an old, experienced wrench, but there are torque/tightening differences that I would like to be aware of.
Thanks, Gordon |
![]() Quote:
02 300ec- 50mm Marzocchi cc forks, 2010 plastic. Now a 250cc. |
![]() Quote:
I just use a ktm manual.. yeah I do!
I'm not complaining. I just wish that Rod could chime in on this issue. Gasgas is spending money on advertising in national magazines so they seem to serious. They have a factory, they have employees that build motorcycles in that factory. What do these employees reference to build their bikes? A ktm manual? Look, if we can get a GasGas Factory online manual in Spanish, I speak Spanish so I would happy to translate it.
I saw the excellent Husky online manual and I wondered, "What a great time saving resource." I am not expecting Gasgas to expend funds to produce printed manuals. If Gasgas wants to build a strong dealership network, won't the technicians at these dealerships need a Factory service manual? Rod, the ball is in your court, what do you say?
The man has a point, GGNA is trying to make the brand more accessible. This is a huge part.
![]() Quote:
I wouldn't think there would have been to many changes since then. FRAME N-m Brake caliper mounting bolt????25 Disc mounting screw???..???...10 Engine mounting bolt?..????.?36 Front axle bolt????...?????51 Front brake hose mounting bolt?..?6 Suspension clamp bolt??..????29 Steering nut?????...?????98 Rear axle nut???????.???98 Rear brake pedal bolt???????9 Subframe bracket bolt????.??26 Rear shock absorber bolt?????39 Rear drive plate nut???.????29 Spokes?????????????1.5 Steering stem nut????..????.4 Torque rod bolt??.???????81 Rear linkage bolt???...?????81 ENGINE N-m Cylinder head screws??????..25 Cylinder nut??????????.25 Engine drain plug????????20 Kick-start pedal bolt???????20 Kick-start pedal nut???????25 Gearshift pedal bolt???????15 Spark plug????????..??.27 Water pump cover drain plug???9 Crankcase screws????????10 Starter pedal plate screw?????.8 Ignition motor stator screws????8 Ignition motor coil nut??????.40 Selector spring fixing screw????15 Primary nut??????????..40 Clutch spring screws???????10 Valve control support screws???..10 Valve control nuts????????..8 Reed valve screws????????..10 Thermostat housing screws????..10 Clutch housing screws??????..10 Valve housing screws???????.8 Ignition housing screws??????.10 http://www.manualslib.com/manual/386...s-Ec-2005.html |
09 EC 300 service manual | kevinlowney | General Discussions & Announcements | 1 | 06-27-2012 01:27 AM |
Service manual on cd ???Anyone buy one?Review? | Stoby | Enduro Product Reviews | 12 | 05-04-2011 07:39 AM |
Online Manual-do they exist? | husley | General Discussions & Announcements | 12 | 01-17-2011 03:00 PM |
Service Manual other than the original | reiterrider | General Discussions & Announcements | 2 | 03-07-2009 10:02 AM |
service manual | skid jackson | Enduro Engine - 2 stroke | 5 | 05-04-2008 08:11 PM |
