Old 05-16-2011, 07:11 AM
motogroove's Avatar
motogroove motogroove is offline
Default Quick swingarm/linkage bearing change question
2001 xc300
The rear bearings on the swingarm that connect to the linkage, er, the dogbones I guess (contained in the All Balls linkage kit, not the swingarm kit, just FYI) look like they might seat on something that keeps them spaced apart. I don't see a spacer on the parts diagram, but I'm not sure I see the bearings either...
(page 6 on the 2000 ec mc sm partslist pdf)
So, my questions are...
Do the bearings press straight through for removal, or is there a fixed spacer that prevents that?
Is there a sliding spacer?
If there is no spacer, is there a trick for setting the bearings at the right depth?
Do I worry too much?
Thanks for any advice.
I'll be setting up my cheapo hydraulic press from Harbor Freight now.
-dean
Old 05-16-2011, 07:37 AM
gasgasman's Avatar
The bearings slide all the way through.
You need to press the bearings in just enough so the seals would be flush with the outer surface of the link.
Old 05-16-2011, 07:44 AM
motogroove's Avatar
Thanks. Maybe I'll use a stack of washers the same thickness as the seal for the final push to set the depth.
Old 05-16-2011, 07:55 AM
GMP's Avatar
GMP GMP is offline
Use o-rings like on the newer bikes instead of seals. Better seal, more durable, and cheaper as well.
Old 05-16-2011, 08:18 AM
GasGas's Avatar
GasGas GasGas is offline
The o-rings are far superior to the seals and to convert to the o-rings is a snap.
2018 EC 300
Old 05-16-2011, 09:13 AM
motogroove's Avatar
Does anybody know the size o-ring?
Sounds like it would be easy to use my new seals and upgrade later (i.e. no change in the depth I'd set the bearing).
Thanks!
Old 05-16-2011, 12:58 PM
eff's Avatar
eff eff is offline
They are 3.5 x 21
2004 GasGas DE250
Swingarm and Linkage Bearings blitz11 Enduro Chassis & Body 34 01-12-2015 03:41 PM
Swingarm/Linkage-how does it go back together husley Enduro Chassis & Body 3 07-16-2011 10:36 AM
Swingarm linkage/bearing kits gasIdaho Enduro Suspension 1 02-03-2009 01:29 PM
MC65 rear wheel bearing change bergerhag Enduro Chassis & Body 0 03-12-2008 03:16 PM
